FINALLY LOWERD UPDATED PICS!
ENGINE/PERFORMANCE
F22a4 base motor
F22a6 manifold swap, slight P&P, cleaned EGR ports
Shortram intake
NGK wires
wheels:
running on 205/60 r 15's
EXTERIOR:
door handle conversion
soon to be s2000 antenna conversion
Custom DRL setup
Bumper light conversion
Hella Trumpet Horns
Suspension:
eibach prokit 1.2-1.4 drop (3 fingers) all the way around
Stock struts, still new...soon to upgrade to Gr-2
Energy suspension bushings (sway bar end links, frame bushings)
Front upper strut bar
Rear lower tie bar
AUDIO/ELECTRONICS:
amp:
a4004t. 100watts rms, 400 watts max...audiobahn intake.
Old alpine deck
front speakers- 6.5'' Alpine type S speakers =). custom fit...sounds fuller...for the money =)
rear speakers - 6x9 3 way Alpine type S
FUTURE PLANS:
Before i was to keep it stock but now i may get some sways and upgrade the struts.
amp on..see blue light =)
custom mount, the bolts are from the top, inside the car, so that u cant unscrew from inside the car..(requires taking off speakers, and that mat under the speakers just to unscrew it)....anti theft..... no head on screw, anti theft...also it has rubber bushings for support and classy look
rear of amp...its on..but u cant see blue well cause its still day. the seat is pulled down so im taking the pic from inside the car...
