Hi guys!
Ever since I smashed up the driver's side headlight on my 91 EX-R Coupe, I haven't been able to get the Headlights or the Highbeams to come on. The headlight itself has been replaced now I just need to get it working!
Some details:
- I'm in Canada, so I have the OEM DRL's and they work fine. As they are the same bulb as the Highbeams (just they come on at a lower powerlevel) I've ruled out burnt out bulbs as the culprit.
- I've tried replacing the "Lighting Relay" found in the Engine Bay Fuse Box with one from a scrapyard: Didn't change a frigging thing.
- When I turn on the Headlights, everything goes dead (DRL lights turn off). Same thing happens when I try to flick on the Highbeams. This is normal behavior for the OEM DRLs as they should be replaced by the Headlights when they're switched on.
- The In-Dash Highbeam indicator doesn't turn on.
- All my turn signals and brake lights work.
::EDIT::
- Also, all my interior lights turn on as usual when I try to turn on the Headlights
I'm really clueless when it comes to wiring stuff, so any help at all would be appreciated. Maybe you guys can help me track down what might be burnt out/broken. I work nights so I'd really like to get my headlights back as soon as possible!
Thanks!
ps: Sorry if this is posted to the wrong sub-forum, go easy on me I'm a noob
Some details:
::EDIT::
Thanks!
