#1 |
DragonEye : 1990 Accord LX
DISCLAIMER: MUST READ !! :
First Of All i want to thx all the CB7 Community For all your support and your +positive+ comment. With all your Clue and DIY i have accomplish the almost impossible. Dont forget when i have start this project i aint know how remove a door speaker... now i work in a garage as a mecano/carrosier. thx !!! and here my Project : ![]() . . ENGINE . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: Exhaust 2.25 Straight :: OBX Twin-Loop Muffler :: OBX Cold Air Intake :: OBX Hose Radiateur Bleue :: OBX Ground Wire Kit (7x4gauge) :: Short Throw Adaptor :: 92-96 Prelude Shifter Swap :: EBC Front Disk Rotor cross drilled/Vented :: EBC Red Stuff Pad . . EXTERIOR . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: Front Bumper: @ Secret @ :: Rear Bumper: BudyClub :: Side Skirt: M3 :: Z3 Front Fender :: Front Fender 1/2" Wider :: Rear Fender 1 1/2 Wider :: JDM Conversion CC2 FrontEnd :: Custom Altezza (Skyline GT-R33 "95 Like) Tail Light :: Custom Hood With Mack 1 Mustang Scoop :: Shaved Custom Side Moldings :: 45deg antenna :: Shaved Trunk Lid (Custom) :: Eye Lid Custom Mold On Hood (FiberGlass) :: Window Tint 80% Onyx :: H.I.D Kit 8000K . . INTERIOR . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: EXR Electric Swap [Thx Dom] :: EDM Rear Fog Light Switch :: Brand New 2005 Civic Seat :: B-Quiet Insulation : -Top- : -Door- : -Floor- : -Rear Compartment- : -Trunk- : -Trunk Lid- :: Brand New Royal Blue Carpet :: Interior Painted Blue/Green Effect Kolor And Metallic Blue Candy Kolor :: Graphite/Artique Suede Interior replacement of OEM Tissue : Painted Blue/Green Effect: : Door Trim : All Dash : 1/2 First Part on center Console : Rear Passenger Trim : Candy Blue Metallic : Dash Trim : Gauge Bezel : Glove Box Cover : 1/2 Second Part on center Console : Suede : Roof : Door Trim : Rear Passenger Trim :: Custom Gauge Custom By Me :: OBX Triple Gauge Pod :: Shift Knob Ractive "8Led Light Bleu" :: E-brake Ractive Black Carbone :: Central Canadian EXR console :: 350mm" Mugen(IMI) Steering + Quick Release :: Heavy Duty Fog Light Wiring Kit :: EXR Glass Holder . . AUDIO . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: Radio PIONEER Premier DEH-P980BT :: Amp Eclipse DA6213 :: BassWorx BGP212 SubBox :: 2 Sub 12" CDT AUDIO 800W Dual Voice-Coil :: 2 Speaker 6.5" CDT HD62 175wRms :: 2 Tweeter CDT :: 2 Crossover: SatNet 480 24 dB Elliptic 2-way :: 2 Capacitor VooDoo 2.4Farad Digital Bleu :: VooDoo 0Gauge Wire Crystal Purple hexagon :: Battery 0/2/4/8G Platinum Terminal :: All Around VooDoo Platinum Terminal :: 130amp Boosted EXR alternator :: Optima BlueTop Marine deepcycle Battery . . Weight Lost Try-Out . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: -Spare/Jack :: -Windshield Liquid Bottle :: -Power-Steering System . . On My List 2DO. . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: -Strut Bar All Around :: -SUSPENSION TECHNIQUES Rear Anti-Sway Bar :: -Swap Rear Disk :: -Setup Coilover OmniPower :: -Mag 18"x8.5 (35offet Front 30offset rear) . . TURBO PROJECT . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :: -F22b Full Port/polish Head :: -F22a1 Cement Block :: -valve 2mm Oversize :: -Retainer Planinum :: -CamShaft Agressif :: -Eagle Rod :: -Piston Forgé Wiseco 8.1:1 Compression :: -Je Piston ring :: -Big BOre Sleeve Forgé oversize a 89mm :: -Turbo garrett 15-20psi . . FINALLY . . . /ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ :::: -Paint :::: -AirBrush Par JasDesign (AccordSe91) Last edited by DragonEye; 01-21-2008 at 02:17 PM. |
#2 |
I didnt catch some of that up there.
Not a bad start man.I like the front bumper.Whats stuck in your grill right where the H is?It doesnt really look like you have hids,but what do I know...Drop that thing and put some nice wheels on it man.Good luck! |
#3 |
those are some dark ass pics. i dont know if you mod list is correct but you might want to check. good start. need more pics in the sun.
#4 |
bienvenu ici, c'est plutot anglais par example.
anyways good start to the car, I hope shes just in winter mode and will be slammed come spring. take care -James
#5 |
Looks good, I like the future plans! Do you have any pics of the motor/engine bay? What Tein setup are you planning on? Great work and get some more pics up
Dan |
#6 |
nice headlight u`ve got their. Drop and change your rims
Signature Picture removed due to excessive size VOLVO 240GL bandit crew....all mighty supertank |
#7 |
for the mod all the mod listed here are not on the picture
(because i continu to bough some stuff even if i got a accident) ex: hid and bodykit.. for the day pic i cant.... because the car are in my garage and striped but my dificult mod are the exr conversion.... damn... for the tein setup i will chose SS setup wheel : black/crome lip.... for the rest.... will finish to install all my house (because i got piece all around my house and try to sleep between) ![]() Last edited by DragonEye; 11-29-2005 at 05:50 PM. |
#8 |
Good Start!!
#9 |
ca fait du bien voir un autre CB7 sur les forums en provenant de Quebec... j'pense que ca fait 3 incluant moi, toi pis Deathfromabove. On as tous les trois des Coupes en plus (j'avoue aussi que c'est moi le plus "stock" des trois... presqu' entierement stock!)
![]() Mechant nice char, j'espere qu'il serait mise-au-point bientot
"Vision without Action is a Daydream. Action without Vision is a Nightmare."
#10 | |
#12 |
Yeah....uh I don't know about the rest of you..but I don't speak French.
#13 |
y'a moi pis legacy accord, nightryder aussi qui viennent de mtl
![]() Last edited by BIGTUFFGUY; 11-29-2005 at 09:01 PM. |
#14 |
j'aime mon porc de poulet et boeuf
good start, get some day time pics!!.. :-p
![]() ![]() ^sold |
#15 |
Here's all the French translated into English:
---Voici tout le français traduit dans l'anglais: ---ca made by the good see another CB7 on forums by coming from Quebec I think that ca makes 3 including me, you worse Deathfromabove. One whizz every three of the Cups on top of that (I confess however it is me it more "supply" of three almost ' entierement supply!) Mechant Nice tank, I espere that he would be mise-au-point bientot ---there is also a guy of the quebec who makes air-brush ---for once I have need not to search my English hehe your tank once ended is going to be sick there especially with the airbrush ---agreement, nightryder also has me worse legacy it which come of mtl ---I love my pork of chicken and beef |
#16 | |
SoCal Regional Moderator /Accord of the Year
whoa....
what just happened? that was siiiiiick!!! for a second i thought i was on a foreign forum! ![]()
![]() CB7-BB6-350Z-370Z?
#17 | |
i love online translators!! they butcher EVERYTHING!!! there are about 7-8 of us from quebec on here. i forgot to mention H22accord also is from mtl
#18 | |
(j'ai un apart a mtl) |
#19 |
not really feeling those headlights and front bumper but everything else looks pretty nice haha the motor soudn hella good
#20 |
Update 27/01/2006
some beat Pix From My Garage 2d ![]() EXR Conversion + Alarm Install ![]() B-Quiet Install ![]() Rear Shot B4 Body kit/door Shaving ![]() Front Shot B4 Body kit/door Shaving ![]() Engine (Look At the Lil' Puck On The Driver's side... ![]() ????????? Secret ![]() ????????? Secret ![]() ClubAccordQuebec.com Last edited by DragonEye; 01-27-2006 at 09:19 PM. |
| Thread Tools | |
| Display Modes | Rate This Thread |
