1. Tools: 36mm axle nut socket (autozone)
Breaker Bar with 5 ft water pipe for leverage
2 Jaw Puller (autozone)
I think a 10mm 12pt socket
(4)10mm x 1.25 60mm long bolt
2. If you have rims move the center cap and while the car is on have someone hold the brakes and remove the axle nut. if you dont have rims remove the steelies jack up the car have someone hold the brakes and remove the axle nut.
3. Remove nut on outer tie rod. Seperate the outer tie rod from the steering knuckle using the 2 jaw puller.
4. Remove nut on lower control arm. Seperate the lower ball joint from the low control arm using the 2 jaw puller.
5. Remove the caliper and caliper bracket and hold the caliper up with rope or hang it somewhere so it doesnt fall and break the brake line.
6. Now you can seperate the cv joint from the hub.
7. Behind the hub is the 4 bolts. remove those with the 10mm 12pt(i think)
8. With the (4)10mm x 1.25 60mm long bolt insert those in the 4 bolts u just removed in step 7 and screw those in all the way.
9. with a hammer or something else, pound the bolts off. without damaging the bearing.
10. if you cannot remove the hub off the knuckle, remove the upper balljoint off the upper control arm. becareful because when u take off the upper control arm the whole assembly will fall off, so i suggest either having the lower balljoint back in the lower control arm then take off the upper then take the lower off.
11. since you couldnt remove the hub off the knuckle u will need to look in your yellow pages and find an automotive machine shop. they should charge less than $40 to press your hub off your knuckle and while they do that have them install your new rotor too(shouldn't cost anything)!!!!
12. now you have your new rotor and just undo the steps. GOODLUCK!!!!!
