Sway Bars
A sway bar connects opposite (left/right) wheels together through short lever arms. A sway bar increases the suspension's roll stiffness, its resistance to body roll in turns.
An anti-roll bar has a spring rate based on the length, diameter, and build of the torsion bar and the geometry of its mounting points. Its principal effect is to resist roll towards the outside of a turn, keeping the body relatively flat.
*How does an EX sway bar compare to aftermarket ones?
*Will a 94-97 accord sway bar fit?
Front
The stock front sway bar has a diameter of
What brands are out there, how much do they cost, and what do people think about them?
Suspension Techniques (solid) sway bar kit is 27/20mm $260 streetbeatcustoms.com
ST 1
Intrax (solid) sway bar kit is 25/16mm $252 sfxperformance.com
Rear
Stock rear sway bar has a diameter of 16mm.
Progress (solid) rear sway bar is 22mm $149 optauto.com
Progress 1
ST 1
