Here is a contribution of mine to our forum. I came up with all these formulas because I wanted something I trusted for my engine build-up. Anyhow, this calculator is based off Excel and you need it to use it. Based on inputs you provide, it will calculate a few different things. On the left column "stock" you can insert the stock setup to compare it to later, or just not use it. On the right column "modified" you insert all the values to your modified setup, new bore, mill/resurface, new piston CC, etc. and you can get final static compression ratio, etc.
For values you may not know to insert in the "known" section, look at the bottom there is another tab called "Honda Engine Info" and I have listed all the information I have and came across on B, D, F and H series motors. Use these values that you need to get a result.
http://www.****.com/uploads/cisco_engine_calc_v12.xls
If you have any questions on how to use it, PM me. Many thanks to cp[mike] for hosting this Excel file for you guys.
