so i received a leather shift boot with red stiching the other day but it was way long and funky. i was going to see if i could trade it for someone but i decided to custom fab it to my oem shifter. the aftermnarket boot i got had this plastic ring near the top and i just cut it off w/ a pair of scissors.
so to take off the center console, you must first take off the shift knob, pulkl collar down from shift boot and then 4 screws for the center console to come out.
if you look at the oem shiftboot and flip it inside-out. the collar is attached with a rubberband type thing and a ziptie.
take those off and seperate the collar from the shift boot
flip the new boot inside out and insert the collar, i put the shiftboot a little bit furthur up the collar since it was so long.
zip-tied
the metal bracket trimmed due to my short shifter (provided by fushigi)
the leather boot is stretched over the bracket
bolted in place
whalaa!!!
a bit scruntched but oh well...total time took 40 minutes
zip-tied
bolted in place
whalaa!!!
Did you just use any flat black auto spray? looks nice
