Been doing some research about a tranny swap. I need to replace my clutch soon and my f22a6 (p2u5) tranny has a grind. I figured I might as well buy a tranny since I need to take it out anyways. People on Accordingly done have strongly suggested the h23 (M2S4) tranny because of it's shorter gears. I was told that H22 trannies have gears that are way too short. This is partially true.
In the data section of accordinglydone.com, I was able to look up the different gears for the h23 (m2s4), the JDM H22A (M2A4), the JDM H22a LSD (M2B4), and the USDM H22A1(M2F4). My main concern with swapping an h- series tranny on my f22 was the gas mileage. The shorter the gears, the lower the gas mileage. Upon using this calculator, I noticed that the USDM H22A1 tranny (M2F4) has a way shorter 5th gear than the h23 (m2s4)which means that highway driving would suck because you would be at very high rpms. In this case, the comparison of the usdm h22 tranny and the h23 tranny would lean toward the h23 tranny being a more practical swap. But looking at the 5th gear of the JDM H22 LSD, the h23 has a shorter 5th gear. The JDM LSD tranny has a better 5th gear for highway driving than the h23 does. They both have the same final drive. The real order of longest to shortest trannies (longest being better gas mileage but slower acceleration, Shorter being the opposite) would be:
1. F22a6 (p2u5)
2. JDM H22 LSD (m2b4)
3. JDM H22 regular (M2a4)
4. H23 (m2s4)
5. USDM H22A1 (m2f4)
In conclusion to my research, the jdm h22 lsd tranny (m2b4) or the regular Jdm tranny (it actually has a longer third gear than the lsd) would be more ideal than the h23 because of shorter 2nd and 3rd gears while still maintaining the longer 5th gear for highway driving.
Let me know what you guys think..... still researching the best tranny. BTW, I'm doing this because I'm eventually going to swap an h22. If I buy the tranny now, I can just buy a longblock when I'm ready.
1. F22a6 (p2u5)
4. H23 (m2s4)
...good find bro
