ok i got some full d2 coilovers so now that they are on the car how can i adjust them whike they are on the car?
adjusting true coilovers on the car
i'm not sure if the D2's have the separate adjustable bottom collar. But with the Omnipowers, there are two ways to do it. Either disconnect the top strut tower bolts of the suspension assembly Or remove the front pinch fork (front) / remove the LCA bolt (rear) in order to move the bottom collar.
the directions say not to tighten the 19mm nut until the very very end and to adjust the height, just turn the shock body. Wrong. the shock body is hard as hell to turn. hah.
Originally posted by cokinuti'm not sure if the D2's have the separate adjustable bottom collar. But with the Omnipowers, there are two ways to do it. Either disconnect the top strut tower bolts of the suspension assembly Or remove the front pinch fork (front) / remove the LCA bolt (rear) in order to move the bottom collar.
Shock body meaning???? I think they are talking about when you disconnect the top strut tower bolts the assembly will drop down enough to be able to turn the whole upper assembly(shock body) up or down while the bottom is still stationary.I found it a pain in the ass and very little room to disconnect the bottom and try and turn it.Maybe thats just me though.
Originally posted by flyinlowShock body meaning???? I think they are talking about when you disconnect the top strut tower bolts the assembly will drop down enough to be able to turn the whole upper assembly(shock body) up or down while the bottom is still stationary.I found it a pain in the ass and very little room to disconnect the bottom and try and turn it.Maybe thats just me though.
yeah, i think i said that, but in a different way. hah
