Go Back   CB7Tuner Forums > Parts & Performance > Suspension > Brake Performance
Old 03-18-2006, 09:19 PM   #1
projectAccord
projectAccord is cool... so far.
Send a message via AIM to projectAccord Send a message via MSN to projectAccord Send a message via Yahoo to projectAccord
brake pedal going to floor
this just happen with in the last week. i know it could be the brake booster or the master cyl. has anyone had this problem and which part was the problem thanks
projectAccord is offline   Reply With Quote
Old 03-18-2006, 09:21 PM   #2
ant96gle
Location: I'm from where the hammers rung, newscameras never come. Brooklyn
ant96gle is cool... so far.
Sounds like the brake booster or master cyl took a crap or you have ALOT of air in the system and it needs bleeding.
ant96gle is offline   Reply With Quote
Old 03-18-2006, 09:26 PM   #3
projectAccord
are they a way to test the booster bro?
Old 03-19-2006, 11:59 PM   #4
oneoffaccord
if you have a leak some where theres you problem. but my guess its the master, if the fluid is good and it drops its the master. if you here a vaccum leak/hissing sound its the booster.
Old 03-20-2006, 12:01 AM   #5
That1guyN8
That1guyN8 is cool... so far.
Send a message via AIM to That1guyN8
Check fluid level
Check for leaks
If both are fine, it's your master cylinder. Replace ASAP! You can lose brake pressure anytime and that just = bad.
Midwest car club
Current rides:
91 accord lx (5spd)
92 accord lx (5spd)
93 accord lx (auto )
That1guyN8 is offline   Reply With Quote
Old 03-20-2006, 12:04 AM   #6
cokinut
cokinut is cool... so far.
Send a message via AIM to cokinut
it's most likely your Brake Master cylinder. the seals inside go bad which 'causes the pedal to go the floor. Again, check your brake fluid levels. if they are fine, it's most likely the BMC.
takes about an hour or two to change including bleeding of the brakes.
BBB= Black Bumpered Beauty
MY MEMBERS RIDE PAGE
'98 Prelude (BB6) Type SH
cokinut is offline   Reply With Quote
