Old 04-01-2006, 10:35 PM   #1
Green_92_EX
Green_92_EX is cool... so far.
Question Short ram intake?
I found a short ram intake on ebay for $30 with shipping. That is sapposed to give me 5-12 more hp. But I was wondering what the differiance in power is betwen short ram and cold air intakes?
Green_92_EX is offline   Reply With Quote
Old 04-01-2006, 10:44 PM   #2
NAiL05
CB7Tuner Member
Location: Dallas, Waco, And now SIUC for school I'm going worldwide bitches!!!
NAiL05 seems to have made some friends!
IT WONT GIVE YOU 5-12HP. But it will make your car sound better. Throttle Response is better in an SRI. You get more top end. CAI on the other hand you get more mid range and throttle response is a bit delayed. You can get the SRI off ebay its almost the same as the AEM/Injen...just quality is different. Ive got a generic one in my car anyway it does its job
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
NAiL05 is offline   Reply With Quote
Old 04-01-2006, 10:46 PM   #3
Specter
Specter is cool... so far.
Send a message via ICQ to Specter Send a message via AIM to Specter Send a message via MSN to Specter Send a message via Yahoo to Specter
okay... not to sound to much like a dick, but any intake system for $30 i'd personaly run away from. look, it's not the best idea to do your car on the cheap because it will come back to bite you in the ass later... now on the difference on a short ram vs. CAI there are a few differences.
on a short ram you get better and quicker airflow [and for those of you that live where it likes to flood no worrie of bogging your engine out] however you will get hoter air into the inkate manifold... that's where a CIA comes in. colder air but you loose the benifits of more air... it's a trade off, but i'd say go for the short ram
インテリア Coupe
HighwayStar - /super highway/stunt driving/transport service/fast delivery/
NightOwl - Nocturnal posting master
2.0LPlus Crew - Member # 1.5
Anti-Tree Mafia - stop hitting trees/to young to die
FG Civic.com
Specter is offline   Reply With Quote
Old 04-01-2006, 10:59 PM   #4
gotnoname
gotnoname is cool... so far.
i agree with specter, a $30 intake probably isnt going to be something you would want on a car. i have a SRI on my accord, and i have noticed the better throttle response, and you really cant tell the power gain until about 3500rpm.
gotnoname is offline   Reply With Quote
Old 04-01-2006, 11:01 PM   #5
accordaffair
accordaffair is cool... so far.
Send a message via ICQ to accordaffair Send a message via AIM to accordaffair
It won't give you but 1 or 2 hp increase, but it sounds pretty cool.
I ran CAI for a long time. CAI breathes air further away from the heat of the engine bay.
Colder air is denser, therefore more oxygen. More oxygen equals more power.
A common rule of thumb is that decreasing the air intake temperature by 10 degrees F will increase horsepower and torque by 1%. The converse is also true.
With a CAI, however, you run a greater risk of ingesting water. If you do ingest a significant amount of water you will kill your engine. Water doesn't compress like air does. Therefore when the pistons try to compress the water, well, it can't. And this causes the engine to basically stop dead in its tracks. This is called hydrolocking.
Hydrolocking occurs when liquid fills a cylinder on the intake stroke and, due to the incompressibility of a liquid, makes the compression stroke impossible. This, in turn, prevents the entire engine from turning, and can cause significant engine damage if one attempts to forcibly turn over or start the engine.
AEM makes a bypass valve which can divert water should such an accident happen, therefore saving your engine from a most certain doom.
A short ram intake is simply a short tube with a filter attached to the end. It remains inside the engine bay and isn't at risk of hydrolock (unless you manage to get the entire nose of your car underwater! ) However, because it resides in the bay and so close to the radiant heat, it breathes much warmer air.
In my personal experience, a CAI is more restrictive, slightly quieter, and gives you less response from the engine/throttle. I prefer the ram, but it would be nice to devise a hybrid type...or at least have a sort of block-off plate/shield in place to give the ram colder air.
Personal preferences! Pick yours and buy a better filter at the same time, and you're good to go!
BTW, some intakes can be setup either way. If you are interested in these, look for the pipes that are joined in the middle by rubber coupling.
accordaffair is offline   Reply With Quote
Old 04-01-2006, 11:33 PM   #6
JDMxDB8
JDMxDB8 may have said something they shouldn't have...
Send a message via AIM to JDMxDB8 Send a message via Yahoo to JDMxDB8 Send a message via Skype™ to JDMxDB8
First of all, you WILL NOT get 5-12 hp. More like 1-2. The most significanrt upgrade you will get is an increase in mpg. Short ram will give you response and cold air will give you more power. But i'd be like 3-4 hp. And the most important thing about the intake system is the filter. K&N make good filters, but if you want an intake system w/ a CARB sticker, you can go with AEM or Injen.
Raceline USA
JDMxDB8 is offline   Reply With Quote
Old 04-02-2006, 12:43 AM   #7
rawkus
rawkus is cool... so far.
Filter is absolutly the key. You don't want to suck a lot of dirt and crap into your engine. Do not go with a cheap filter on your car.
Side not, after about 30-35mph, the amount of air actually flowing into the engine bay makes cold air intakes insignificant. There is so much air coming in, it isn't nearly as warm as people think when it hits the filter.
Dan
rawkus is offline   Reply With Quote
Old 04-02-2006, 09:01 AM   #8
williamsvt
williamsvt is cool... so far.
Send a message via AIM to williamsvt Send a message via MSN to williamsvt Send a message via Yahoo to williamsvt
personally, intakes to me are just piping that make your car sound a little bit better when accelerating.
*keep in mind i myself actually have an AEM CAI*
i think that depending on the piping, 30 bucks isn't a bad deal, and may actually be an alright buy. I mean think about it, all an intake really is, is just piping to let extra air in during higher RPMS...so why should it matter whether or not its an AEM pipe or an un-brand named pipe. A pipe is a pipe and does the same thing. Especially when talking about short ram intakes rather than CAI's, it really doesn't matter even more, since you won't run the risk of sucking in water (CAI = cold air intake = filter is in right wheel well bottom). Some people even have hacked air boxes on here as their intakes and they just slap a filter at the end.
In the end, you really don't need a brand name Short-ram, unless your going to shows and need something to show off. The filter is what counts, and thats what i would spend some money on. Getting a good filter thats breathable is far more important then a name slapped onto a piping.
Also, as others have said you won't get that kind of HP from an intake sadly...i thought the exact same thing when i got my CAI 2-3 years ago, but sadly you only gain some cool sound while accelerating and maybe 1 hp.
Audi A4 2.8 Quattro Sport
williamsvt is offline   Reply With Quote
Old 04-02-2006, 12:02 PM   #9
92DX
92DX is cool... so far.
Dan
That's if you have good hood scoops. And I'm talking about REAL hood scoops, not those stick-on Rice scoops, those are just fo sho.
92DX is offline   Reply With Quote
Old 04-02-2006, 02:03 PM   #10
Davids92Accord
Davids92Accord is cool... so far.
yea speaking of hood scoops my friend drives a plymouth GTX and his hood scoop is bad azz inside he has a switch or something else im not sure and when he flips it the hood scoop pops up and its air going straight into the air filter of his car and what i was thinking how cool would that be on a CB7 i know its possible but it takes some customizing to do it and alot of work but if i ever get the knowledge on how to? i would inform you guys but if anyone else has already done something like this than share it with everyone if not than the idea is out
________
BLACK ASIAN
Davids92Accord is offline   Reply With Quote
Old 04-02-2006, 06:51 PM   #11
Gato-FF
Gato-FF is cool... so far.
Out of the two, the cold air would be better for mid range. But its nothing extraordinary. On a stock engine you wont noticing anything spcecial. You need more than one mod.
Gato-FF is offline   Reply With Quote
Old 04-02-2006, 08:52 PM   #12
MRKIKKOMAN
MRKIKKOMAN is cool... so far.
Send a message via AIM to MRKIKKOMAN
Nobody mentioned the ghetto ram. Its in the DIY forum on this site. All you do is buy a filter take off just the air box and stick on your filter. I did and it didn't cost me anything but I stole the filter from my other car. Advance auto parts here has K&N filters for 40 I think. After you buy it you never have to replace it unless it gets really damaged( hole ripped in it) They sell cleaning kits for the filter. I didn't find hardly any power increase maybe throttle response. Its a cheap mod but good none the less.
-Nate
DIY antenna control
DIY ghetto short ram
Battery Relocation
New Project
1984 BMW 533i =DEAD
MRKIKKOMAN is offline   Reply With Quote
Old 04-02-2006, 09:01 PM   #13
Otto
Otto is cool... so far.
Short ram could be nice in winter, slightly faster warm ups.
You'd have to decide if you like the noise of the short ram or not.
Its a nifty sound, and can be fun to drive (especially if your muffler falls off ), but I kinda got tired of it personally.
I went with the modified stock air box. I cut the bottom of the silencer (part that's behind the bumper and in-front of the wheel) off, and blocked the tube opening that's right behind the headlight. So both tubes take air from the same area as most CAI setups. The stock setup only intakes air through ONE approximately 2 inch opening, this setup now draws air through TWO approximately 2 inch openings. I've been loving this setup...since its easy and free, and has a small but noticable increase in throttle response, MPG, and mid- to top-end power.
I use a Wix OE replacement filter, BTW.
Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Otto is offline   Reply With Quote
Old 04-02-2006, 09:22 PM   #14
The G-Man
The G-Man seems to have made some friends!
Send a message via AIM to The G-Man
Quoted for truth.
I also have an AEM CAI, but it came with the car when I boguht it. Piping is piping, the filter is where you need quality. Get a good K&N filter.
I am thinking of getting an ebay CAI for my mom's honda odyssey.
Gary A.K.A. Carter
[sig killed by photobucket]
The G-Man is offline   Reply With Quote
Old 04-02-2006, 11:48 PM   #15
eddieq19
eddieq19 is cool... so far.
Send a message via MSN to eddieq19
Exclamation Try Looking Could not find!!!
ok i was reading this and someone mentioned a Ghetto Short ram that was in the diy forum so i went looking can't find so i was wondering can some on tell me how to make a ghetto short ram thanks guys
eddieq19 is offline   Reply With Quote
Old 04-02-2006, 11:49 PM   #16
NAiL05
CB7Tuner Member
Basically its just flipping the airbox around with the top taken off.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
Old 04-03-2006, 01:12 AM   #17
CB7 SOHC F22A6
CB7 SOHC F22A6 is cool... so far.
Send a message via AIM to CB7 SOHC F22A6
short ram you'll get a 1 - 2% horsepower gain haha
nothing special
i got some stock honda civic si turboz
CB7 SOHC F22A6 is offline   Reply With Quote
Old 04-03-2006, 05:16 AM   #18
84Blazin
84Blazin is cool... so far.
Send a message via MSN to 84Blazin
http://www.cb7tuner.com/vbb/showthread.php?t=6532
Booty fabbin.... I run this also. Sounds good with a little bit more top end..
90' Honda Accord LX Sedan
Everytime I feel blue, I remember to breath again.
84Blazin is offline   Reply With Quote
Old 04-03-2006, 11:02 AM   #19
Bigsim05
Bigsim05 is cool... so far.
Why not just buy a short ram air intake and just wrap it in a heat shield to protect it from heat that way you get the best of both worlds.
Bigsim05 is offline   Reply With Quote
Old 04-03-2006, 01:05 PM   #20
accordaffair
Well, the filter would still be breathing in hot engine air....
