F Series Engine List
This topic is closed.
    F22A1: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 125 hp (93 kW) @ 5200 rpm, 137 lbf·ft (186 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
    F22A4: 1990-1991 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5200 rpm, 142 lbf·ft (193 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
    F22A6 1991-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 140 hp (104 kW) @ 5600 rpm, 142 lbf·ft (193 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
    All listed above are Single Overhead Camshaft [NON-VTEC] controlling intake and exhaust, for the most part having interchangeable parts .
    It has been pointed out on one particular internet forum dedicated to the 4th generation Accord that all Honda engines from 1990 onwards are constructed of aluminum alloy in both the head and block. The last Honda engine to use an iron block was the Honda A engine.
    The following list of F22B Engines are [VTEC] and [NON-VTEC] SOHC Engines found in the 1994-1997 Honda Accord, 1995-1997 Honda Odyssey, and 1997 Acura CL.
    F22B1 1994-1997 VTEC Accord EX, 1997 CL, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
    F22B2 1994-1997 Non-VTEC Accord LX, DX, SE, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5300 rpm, 139 lbf·ft (188 N·m) @ 4200 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
    F22Z2 1996-1998 VTEC Accord (Euro), 2.2 liter (2156 cm³), MPFI fuel system, 150 hp @ 5500 rpm, ??? lbf·ft (???N·m) @ 4500 rpm, 9.3:1 compression.
    F22B6 1995-1997 VTEC Odyssey, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
    C SERIES ENGINES
    Engine:c27a4 (V6)
    Year: 95-97 (no V6 in 94)
    Trim: EXV6/LXV6
    Hp: 170
    Tq: 178
    Displacement: 2675cc
    Compression: 9.0:1
    Valvetrain:SOHC, NON VTEC
    F SERIES ENGINES
    Engine:f20b
    Year: 90-93
    Trim: SiR
    Hp:200
    Tq:146?
    Displacement:1997cc
    Compression:11.0:1
    ValvetrainOHC, VTEC
    Engine:f20a
    Year:90-93
    Trim:2.0 Si
    Hp:150
    Tq:137
    Displacement:1997cc
    Compression:9.5:1
    ValvetrainOHC, NON VTEC
    Engine:f22a1
    Year:90-93
    Trim:lx/ex
    Hp:125
    Tq:137
    Displacement:2156cc
    Compression:8.8:1
    Engine:f22a4
    Year:90-91
    Trim:dx?
    Hp:130
    Tq:142
    Displacement:2156cc
    Compression:8.8:1
    Engine:f22a6
    Year:92-93
    Trim:ex (also 91 and 93 SE)
    Hp:140
    Tq:142
    Displacement:2156cc
    Compression:8.8:1
    Engine:f22b1
    Year:94-97
    Trim:ex
    Hp:145
    Tq:147
    Displacement:2156cc
    Compression:8.8:1
    Valvetrain:SOHC, VTEC
    Engine:f22b2
    Year:94-97
    Trim:dx/lx
    Hp:130
    Tq:139
    Displacement:2156cc
    Compression:8.8:1
    Engine: f22b (JDM Prelude)
    Year: 92-96
    Trim: Si
    Hp: 160
    Tq: 148
    Displacement: 2156cc
    Compression: 9.0:1
    Valvetrain: DOHC, NON VTEC
    Engine:f23a1
    Year:98-02
    Trim: LX/EX
    Hp:150
    Tq:152
    Displacement:2254cc
    Compression:9.3:1
    Valvetrain:SOHC VTEC
    Engine:f23a4
    Year:98-02
    Trim: LX/EX
    Hp:148
    Tq:153
    Displacement:2254cc
    Compression:9.3:1
    Valvetrain:SOHC, VTEC (ULEV)
    Engine:f23a5
    Year:98-02
    Trim: DX
    Hp:135
    Tq:153
    Displacement:2254cc
    Compression:8.8:1
    H SERIES ENGINES
    Engine: h22
    Year: 94-97
    Trim: SiR
    Hp: 190
    Tq: 152
    Displacement: 2157cc
    Compression: 10.6:1
    Valvetrain: DOHC, VTEC
    Engine:h22a (JDM Prelude)
    Year:92-96
    Trim: VTEC
    Hp:200
    Tq:161
    Displacement:2156cc
    Compression:10.6:1
    ValvetrainOHC, VTEC
    Engine: h22a1 (USDM Prelude)
    Year: 92-96
    Trim:
    Hp: 190
    Tq: 158
    Compression: 10.6:1
    Engine: H22A4
    Year: 99-01
    Trim: Prelude SH
    Hp: 200
    Tq: 156
    Compression: 10.0:1
    Engine: H22A7
    Year: 97-01
    Trim: Accord TypeR
    Hp: 220
    Tq: 163
    Compression: 11.0:1
    J SERIES ENGINES
    Engine: j30a1 (V6)
    Year: 98-02
    Trim: EXV6/LXV6
    Hp: 200
    Tq: 195
    Displacement: 2997cc
    Compression:?
    Valvetrain: SOHC, VTEC
    K SERIES ENGINES
    Engine: K20A
    Year: 03+
    Trim: Accord EuroR (also Integra TypeR, Civic TypeR - JDM)
    Hp: 220
    TQ: 146
    Displacement: 1998
    Compression: 11.0:1
    Valvetrain: DOHC, iVTEC
    Engine: K24A
    Year: 03+
    Trim: Accord/Accord Wagon (JDM)
    Hp: 200
    Tq: 172
    Displacement: 2354
    Compression: 11.0:1
    Engine: K24A2
    Year: 03+
    Trim: TSX
    Hp: 200
    Tq: 166
    Displacement: 2354
    Compression: 11.0:1
    Engine: K24A3
    Year: 03+ Accord (USDM)
    Trim: LX/EX
    Hp: 160
    Tq: 162
    Displacement: 2354
    Compression: 9.0:1
    Magnaflow exhaust for cb7's for sale
    If this belongs somewhere else then my bad, but if someone could make it a sticky that would be cool thanks.
      Cool. I'm pretty sure this will be handy.
        thanks
        now i know why those parts make a diffrence
          you should add commonly swapped motors (h22 series), might be helpfull as well
            Add this to your list. I made this thread a long time ago, it's ancient, but it's right and does a good job
            Here's a link to the original info(yes I am acc90rd on other sites)
            http://www.topendmotorsports.com/jp/...gine-specs.htm
            C SERIES ENGINES
            Engine:c27a4 (V6)
            Trim: EXV6/LXV6
            Hp: 170
            Tq: 178
            Compression: 9.0:1
            F SERIES ENGINES
            Engine:f20b
            Year: 90-93
            Trim: SiR
            Hp:200
            Tq:146?
            Displacement:1997cc
            Compression:11.0:1
            ValvetrainOHC, VTEC
            Engine:f20a
            Year:90-93
            Trim:2.0 Si
            Hp:150
            Tq:137
            Displacement:1997cc
            Compression:9.5:1
            Engine:f22a1
            Year:90-93
            Trim:lx/ex
            Hp:125
            Tq:137
            Displacement:2156cc
            Compression:8.8:1
            Engine:f22a4
            Year:90-91
            Trim:dx?
            Hp:130
            Tq:142
            Displacement:2156cc
            Compression:8.8:1
            Engine:f22a6
            Year:92-93
            Trim:ex
            Hp:140
            Tq:142
            Displacement:2156cc
            Compression:8.8:1
            Engine:f22b1
            Year:94-97
            Trim:ex
            Hp:145
            Tq:147
            Displacement:2156cc
            Compression:8.8:1
            Engine:f22b2
            Year:94-97
            Trim:dx/lx
            Hp:130
            Tq:139
            Displacement:2156cc
            Compression:8.8:1
            Year: 92-96
            Trim: Si
            Hp: 160
            Tq: 148
            Compression: 9.0:1
            Engine:f23a1
            Year:98-02
            Trim: LX/EX
            Hp:150
            Tq:152
            Displacement:2254cc
            Compression:9.3:1
            Engine:f23a4
            Year:98-02
            Trim: LX/EX
            Hp:148
            Tq:153
            Displacement:2254cc
            Compression:9.3:1
            Engine:f23a5
            Year:98-02
            Trim: DX
            Hp:135
            Tq:153
            Displacement:2254cc
            Compression:8.8:1
            H SERIES ENGINES
            Engine: h22
            Year: 94-97
            Trim: SiR
            Hp: 190
            Tq: 152
            Compression: 10.6:1
            Year:92-96
            Trim: VTEC
            Hp:200
            Tq:161
            Displacement:2156cc
            Compression:10.6:1
            ValvetrainOHC, VTEC
            Year: 92-96
            Trim:
            Hp: 190
            Tq: 158
            Compression: 10.6:1
            Engine: H22A4
            Year: 99-01
            Trim: Prelude SH
            Hp: 200
            Tq: 156
            Compression: 10.0:1
            Engine: H22A7
            Year: 97-01
            Trim: Accord TypeR
            Hp: 220
            Tq: 163
            Compression: 11.0:1
            J SERIES ENGINES
            Engine: j30a1 (V6)
            Year: 98-02
            Trim: EXV6/LXV6
            Hp: 200
            Tq: 195
            Compression:?
            K SERIES ENGINES
            Engine: K20A
            Year: 03+
            Hp: 220
            TQ: 146
            Displacement: 1998
            Compression: 11.0:1
            Engine: K24A
            Year: 03+
            Hp: 200
            Tq: 172
            Displacement: 2354
            Compression: 11.0:1
            Engine: K24A2
            Year: 03+
            Trim: TSX
            Hp: 200
            Tq: 166
            Displacement: 2354
            Compression: 11.0:1
            Engine: K24A3
            Trim: LX/EX
            Hp: 160
            Tq: 162
            Displacement: 2354
            Compression: 9.0:1
            Shift_BOOST
            BOOM!
              Originally posted by 92ex
              Engine: H22A7
              Year: 97-01
              Trim: Accord TypeR
              Hp: 220
              Tq: 163
              Compression: 11.0:1
              if my memory serves me right... theres no such thing as an accord typeR... over thurr in eurasia they're called inspires. i wouldnt quote me on that though, i heard that word of mouth-wise.
                i didnt do that one, accordex did, I think he was going for type s or something, or maybe he's right. the 220hp looks like a h22 type s
                Shift_BOOST
                BOOM!
                  googled it quick, i dunno, there is an accord type r, but nothing clarified whether it had the h22a7 or the h22a8
                  Shift_BOOST
                  BOOM!
                    accord typeR is the americanized term. over there the accord is an inspire. same car, different name. and h22a7 is the correct engine in it.
                      Thanks for the list EuroSpec
                        wasn't my list, 92ex deserves credit for that. but it is a very clean list.
                          Lol oops, my bad. 92ex thanks for the list.
                            just trying to get the respect where respect is due
                              *edit* i've been told that its NOT the inspire after all... its acctually the penor985.
