Go Back   CB7Tuner Forums > Site Features > DIY's
Old 04-18-2006, 09:10 PM   #1
cincy90h22
cincy90h22 is cool... so far.
EXT: JDM intersection lights wiring problem... solved!!
I rehosted the pics so new members can take advantage of this DIY
ok for those of you whom have, or want to get intersection lights but dont know how to wire them so that they work as there supposed to, this will help you. The intersection lights are supposed to come on, and stay lit, as your turn signal comes on and blinks. Using a traditional relay will not create this effect, because it cant create a solid current (for intersection lights) from a pulsing current (from turn signals).
Other vehicles such as Nissan Maximas, Cadilacs, and Range Rovers have intersection lights, which are actulally refered to as cornering lamps. The cornering lamps work on a controll unit, that uses the current from the battery and a signal from your turn signals to illuminate the cornering lamp.
So this is what I did:
I went to the junkyard and pulled the corner lamp control unit from and 87-89 nissan maxima (located under the hood on the driver side close to the fuse box) it is labeled CONT. CORNER LAMP. cut the harness leaving enough wire to work with. You may also want the bracket held on with phillips head screws, this will make it easier to mount the control unit. I opted to leave the bracket because the screws were stripped, and i was going to hide the unit anyway. I have junkyard connections so I got it for free, you can prolly pick one up for less than $10 bucks... or five-finger it since it will fit in your pocket...control unit looks like this
using this schematic (for maxima control unit) I wired up the control unit
sorry for the cut off pic ill break it down
R/W- 12v constant source ~ fused 15A
R/Y- low beam headlight lead
Orange- high beam headlight lead
Or/Blue- left intersection light
Or/Black- right intersection light
G/Y- left turn signal lead
G/R- right turnsignal lead
black- ground
*lead= the wire suppling the power to the light, not the gound-which is black*
when connecting the wires from the control unit to the headlights or turnsignals just use a wire tap, such as these
As for the actual cutting of the bumper and installing the lights, I used some 2" masking tape and traced the trim ring of the intersection lights. If you have a stock oem bumper there should be templates on the back side of the bumper, but mine didnt have that, so be sure to measure both sides to make sure they are in the same place BEFORE YOU CUT! I cut it out with a wiz wheel, some sort of air saw, and a round file to make it smooth.
Finished product:
what do ya think? i hope this helps some.
91 Accord LX
195.4 @ 7750RPM
ALL MOTOR
cincy90h22 is offline   Reply With Quote
Old 04-18-2006, 09:53 PM   #2
xScott
xScott may have said something they shouldn't have...
Nice, ill have to do this once I get around to installing mine.
xScott is offline   Reply With Quote
Old 04-23-2006, 02:44 PM   #3
SSMAccord
SSMAccord is cool... so far.
Thats nice to know, and a clean install. Good work.
Old 04-25-2006, 09:33 AM   #4
f22-dohc
f22-dohc is cool... so far.
heading to the wreckers....
thanks dood.
welcome to the DOHC-side..muuuahahahahahah
http://www.cb7tuner.com/vbb/showthread.php?t=1906
f22-dohc is offline   Reply With Quote
Old 04-25-2006, 10:12 AM   #5
seigneur_rayden
seigneur_rayden is cool... so far.
Good job man. I've been thinking of doing that but no time. Clean instal
Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
seigneur_rayden is offline   Reply With Quote
Old 04-29-2006, 03:14 PM   #6
f22-dohc
i have a feeling its this model
cuz i searched all day for the ones after that with no luck for that module
Old 04-29-2006, 08:51 PM   #7
cincy90h22
^^^ yes thats the year/body style that my control unit came from. driver side fender wall just behind the headlights. the next body stlye up- more rounded- is in the driver side kick panel.
91 Accord LX
195.4 @ 7750RPM
ALL MOTOR
Old 04-29-2006, 09:12 PM   #8
accord_inspire
accord_inspire is cool... so far.
nice A+++
"LAND OF THE GREAT"!! OSAKA,JAPAN
accord_inspire is offline   Reply With Quote
Old 04-29-2006, 11:04 PM   #9
cincy90h22
Originally Posted by accord_inspire
nice A+++
coming from you.. thats quite a compliment.. ^the jdm master has spoken^
91 Accord LX
195.4 @ 7750RPM
ALL MOTOR
Old 04-30-2006, 08:24 PM   #10
f22-dohc
back...
i was in a rush... i took a relay corner lamp on the kick panel
i have the wiring diagram, tried it, and doesnt work. it still flashes.
wrong part?????
Old 04-30-2006, 09:29 PM   #11
cincy90h22
Question
Originally Posted by f22-dohc
back...
wrong part?????
it flashes? maybe it is wired different than the above model, ill pull up a diagram from a newer model and check it out tommorow. it shouldnt flash if it was hooked up wrong it just wouldnt work
91 Accord LX
195.4 @ 7750RPM
ALL MOTOR
Old 04-30-2006, 11:48 PM   #12
excalibur02
Wanna be JDM whore
excalibur02 is cool... so far.
whooooa finally i was planning to go the the junkyard and take out a module/relay from a old caddy or lincoln. but since you did this write up i will stick to what you did. great job.
thanks
my name is mauricio aka maury....
RIP to Jenny!!! Paola and Angela live on!
MY MEMBERS RIDE THREAD FOR Jenny=My White Sedan
MY MEMBERS RIDE THREAD FOR Paola=My White Coupe
MY MEMBERS RIDE THREAD FOR Angela=My Blue Sedan
Old 05-02-2006, 04:27 PM   #13
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
ah i always love wiring diagrams! thanks for sharing your findings. now it's time to find the lights!
- 92 LX coupe
- 96 EX wagon
timmy0tool is offline   Reply With Quote
Old 05-05-2006, 12:50 AM   #14
excalibur02
Wanna be JDM whore
haha i feel the same way.. brings me back to highschool days from electronics class. i know now why i always got an A for the class
Old 05-08-2006, 12:03 PM   #15
f22-dohc
any news on this??
Old 05-23-2006, 10:28 PM   #16
seigneur_rayden
cincy90h22 or anyone else
Where did U connected the wire for the 12V source and how far did u place the fuse (control unit - Power source) ?
Old 05-29-2006, 06:49 PM   #17
cincy90h22
sorry man aint got a computer anymore, gotta do this at moms now. shitty huh..
anyway it doesnt matter where the fuse is placed, traditionally it should be as close to the power source as possible. I ran the 12v lead to the fuse box under the hood. After your main fuse (like 85amp or something) so not on the battery side, get what im sayin? its to the left of where the battery cable enters, i just used one of those round crimp connectors with a screw hole in it.
91 Accord LX
195.4 @ 7750RPM
ALL MOTOR
Old 05-30-2006, 01:36 AM   #18
seigneur_rayden
Thanks man, I'll check it today when the sun rises.
Old 05-31-2006, 09:27 AM   #19
seigneur_rayden
Okay, I checked but I'm still confused. Which one of the circle represents what Ur talking about for the 12V power lead And what size (gauge)of wire did U you use? Sorry, I ain't that good in electrical stuff
If anybody else or moderator who did that or know the answers, please tell me?
Old 06-02-2006, 11:13 PM   #20
cincy90h22
the black one
91 Accord LX
195.4 @ 7750RPM
ALL MOTOR
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
