ok, i know its been a while since i said i would make this, but i just got lazy, so here it is now.
materials:
3" 90* heating duct form lowe's/home depot (the kind that rotates in sections from straight to 90* and anywhere in between) $3.00
3" cone muffler, mine is a ractive piece-part# sf-100 i believe-that i got from oreily's - $17.00
sheet metal at least 2' long and 12"wide- $9.00 at lowes
door bump-strip (the kind that slips on the edge of the door) $2.00
engine enamel paint (vht) $5.00
thin cardboard (cereal box)
tools:
10mm ratchet with extension
phillips screwdriver
tin snips
pencil
nail
drill
step 1:
remove the stock airbox, airbox bracket, and one of the pipes from the front bumper. i cant remember which pipe, but one of them gets in the way of the filter. it will be obvious later which one is needed out. install the heat duct into the end of the intake pipe.
step 2:
using the cardboard, make a template for the heat shield. use the nail to poke holes where the two bracket mounting holes are. cut the hole for the heat pipe.
step 3:
trasfer the template to the sheet metal and cut it out. drill holes (obviously) where the nail-holes on the template are. cut the 3" hole for the pipe. bend the sheet metal on the side of a bench or table into a 90* bend where needed. paint with engine enamel.
step 4:
line the edges of the heat sheild with the door bump-strip, install using the two bolts from the intake-box bracket. slide the heat pipe through the hole, and clamp filter onto the end (duh). the pipe is kind of flimsy and may need to be cut to fit the filter on.
step 5:
there is no more, you're done, except for closing the hood, putting your tools away, starting your car, and hearing it breathe past half-throttle
finished pic:
materials:
tools:
tin snips
pencil
nail
drill
step 1:
step 2:
step 3:
step 4:
step 5:
finished pic:
That's my opinion, and I don't like ghetto when I do something myself.
