Disclaimer: whatever you do, you do it on ur own accord. i will not be resposible if u fuck up or car or get hurt.
a while back i promised a few members that i would show them an easy way to replace the front rotors. since they are pressed in many members have had a hard time replacing them and shops charge u $300 or more to replace them.
this is a new way.
it will take you guys about 30 min for one wheel depending on what tools you have and your mechanical knowledge.
on here it goes
TOOLS
you will deen all the big 36 milimeter socked for the axle nut
the regular 6 spoke sockets and you will need the 12 spoke #10 socket.
and you will need a slide hammer
and the axle puller
both of these last tools can be rented for free at auto zone or pep boys
REMOVING THE ROTOR.
1. without pulling the car up unstake the axle nut and with the 36 mm socked and a breaker bar try to losen up the axle nut. if you can do it use a 5 feet pipe.
2. take the wheel off.
now yo wll see 4 #14 bolts. try to brake them loose. DO NOT TAKE THEM OFF.
push the tip of the axle inwords
take off the brakes and the bracked that holds the brakes.
the bracked uses 2 # 17 bolts
in the back of the wheel asambly you will see 4 bolts. now the only way to remove those bolts is to push the axle in a little bit and using a #10 12 spoke socket, you will need to losen those bolts up.
IF YOU CAN NOT LOSE THEM UP DON'T WORRY BECAUSE THERE IS ANOTHER WAY.
OK LETS SAY THAT SOME OF YOU DID LOSE THOSE BOLTS IN THE BACK AND SOME DIDN'T
WHAT FOLLOWS APPLAYS TO BOTH.
PUT THE AXLE PULLER ON THE WHEEL ASSAMBY AND PUT ON TWO LUG NUTS.
THEN PUT THE SLIDE HAMMER IN THE AXLE PULLER.
using the slide hammer pull the rotor out. DON'T MIND THE PIC I GOT THE CAMERA AFTER I INSTALLED EVERYTHING.
A if you did lose the 4 #10 bolts in the back then the whole wheel bearing/ rotor will come out. replace the rotor
B if you couldn't losen the 4 bolts in the back then that means that the rotor came out with the hub without the wheel bearing. thats ok. just replace the rotor.
REPLACE THE ROTOR.
INSTALLING THE NEW ROTOR.
Installing the new rotor depends on the way you took it off
1. if you did take off those 4 bolts on the back of the wheel assambly the instalation its easy. just put back the rotor/wheel bearing assamby on and tighten them up till the wheel bearing assamby and rotor and in their place.
torque them to the specs.
2. IF YOU COULDN'T LOSEN THE 4 #10 BOLTS IN THE BACK AND THE ROTOR CAME OUT WITHOUT THE WHEEL BEARING THATS OK.
look at the wheel bearing and see if they need replacement since you are there. if not then put a lot of wheel bearing grease in there.
now try to put back the rotor /hub. when the axle its in then put the axle nut and use that nut to push the rotor and hub in.... after the rotor its in its place install the brake bracket.
NOW USE ONLY NEW BRAKE PADS. DON'T USE THE OLD ONE. clean the rotor with brake cleaner.
THEN TIGHN THE AXLE NUT TO ITS TORQUE SPEC AND TEST DRIVE THE CAR.
this is how it should look afer you are done.
this is a new way.
on here it goes
TOOLS
and the axle puller
REMOVING THE ROTOR.
REPLACE THE ROTOR.
