Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Naturally Aspirated
Old 03-29-2004, 03:49 AM   #1
loops
loops is cool... so far.
low end tourque
as the sub. says...im wondering what would be a good mod to get that would increase the tourque on my many92lx. any help is appreciated. thanks
loops is offline   Reply With Quote
Old 03-30-2004, 03:18 AM   #2
Wallace
Wallace is cool... so far.
grouding kit?
it gave me a little bit of low end torque, especially in 4th and 5th gears on the highway.
but dont buy the $300 kits, you can make your own with equal quality for $50.
other than that, maybe new plugs/wires?
CB7 + H22A4 + M2S4 + JDM P13
www.vancouveraccords.com
Wallace is offline   Reply With Quote
Old 03-30-2004, 04:25 PM   #3
HondaFan81
Honda Enthusiast
HondaFan81 seems to have made some friends! HondaFan81 seems to have made some friends!
Originally posted by Wallace
grouding kit?
I am curious as to how this happens...could you elaborate please Wallace. Thanks.
HondaFan81 is offline   Reply With Quote
Old 03-31-2004, 12:06 AM   #4
Wallace
you talking about the grounding kit?
basically it makes a better ground for your electrical system.
this gives you a slighter better spark, and improves other parts of the electrical system.
here's a quote from one website:
" This auto wires system (ground wire kit) provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation.
The Hyper Ground System wire cables have 10 times less impedance than factory ground system, which provides immaculate conduction to prevent electrical power loss. The higher resistances of factory grounds have negative effect to the ignition system and obstruct the primary potential.
Hyper Ground Wire Kits uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection. This ground wire kit will increase the primary potential of regular cars to ignition-tuned vehicles.
Key feature of Hyper Ground System (ground wire kit):
Gain Torque and Horsepower
Increase Fuel Efficacy for Better Gas Mileage
Better Throttle Response.
Reduced Emissions.
Brighter Headlights.
Reduced Audio Noise. "
Old 03-31-2004, 12:17 AM   #5
loops
but how do you DIY??
hey wallace props to the BC accords.
Old 03-31-2004, 10:15 AM   #6
HondaFan81
Honda Enthusiast
Thanks for the post Wallace...yea I did mean the ground wire kits, I knew they provided better grounds, but didn't know how this affected much if stockwise you already have grounds. Makes you wonder why cars don't come like this already from factory? Anyways, I can envision how the DIY would be setup, fairly simple concept...connect body, chassis, engine block, cyl head, transaxle to negative battery terminal with some good quality copper wires.
Now, is it of any benefit to ground the intake manifold (cuz of electrical components on it) and/or exhaust manifold (O2 sensor)?
Anything else worth grounding? (ie. P/S pump, alt, starter motor, etc).
Thanks for info.
Old 04-01-2004, 01:29 AM   #7
Wallace
you have to connect the negative terminal of the battery to the chassis, throttle body, valve cover, and alternator.
you have to use really good quality wires and connectors.
i dunno about connecting it other parts of the engine.
i got my kit from a member of www.vancouveraccords.com who makes them. i paid $70 canadian. i think the materials are worth about $50-$60.
i could probly do a DIY even though i didnt make the kit. (i'll have to ask permission from the guy who made the kit though.)
