Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner "Off Topic"
Closed Thread
Old 09-02-2006, 09:04 AM   #1
dsyple
dsyple is cool... so far.
paint thiner mix with gas!!
man...this shit sucks...it hella pissed me off..........i accedentaly put paint thiner mixed with gas on my car.....cause i ran out of gas and my car couldn't start....actually it starts but it'll bog and die out.....well....in the first place...my brother tried to play a prank on me......he told me there's a 2 gallon worth of gas....and i poured about $.50 worth of that paint thiner with my gas...then i was like wait....let me double check if it's gas...it didn't smell like it....and it looked to clear...so i started bitching at my brother and he said it was paint thiner...well yeah...after i did that...my car started....and i was able to make it to the gas station about a 1-1.5 miles away from my house...then i put $7...and it won't even last me that long....usally if u put $5-$10 it'll last me about 3 days at the most..now i can't even do that...my car eats alot of gas...it started eating my gas after that paint thiner...can $.50 of paint thinner destroy something in my car?some one help me here plz...
Signature removed due to excessive size. Please read the rules before creating a new signature. - cp[mike]
dsyple is offline
Old 09-02-2006, 09:17 AM   #2
Spartan1987
Spartan1987 may have said something they shouldn't have...
Send a message via MSN to Spartan1987
Perhaps your fuel filter is FUBAR. I would say try that first. Who else can help?
(RIP)1993 LX Sedan
Frost White Crew Member #36
JDM Beating Stick Owner #1
My (old) Ride
Spartan1987 is offline
Old 09-02-2006, 09:24 AM   #3
dsyple
what does FUBAR mean?well yeah..thanks for that advice..i'll check on it...ohh yeah how can u tell if the fuel filter is dirty?can u just wash it and dry it?anyone else that has some ideas?
dsyple is offline
Old 09-02-2006, 09:45 AM   #4
GreenMadness
GreenMadness is cool... so far.
Send a message via AIM to GreenMadness
fubar nicely means F'd up. but actually other than corosive properties of paint thinner it does have the same properties as gasoline. i.e. the flammability limits are in place and it will burn and produce power, the only problem is that it may prematurly detonate or combust to late robbing your engine of power.
for the small length of time you ran it i doubt anything bad happend, although there are somethings that need to be carefully inspected.
it would be in your best intrest to check your sparkplugs and make sure that the detonation of paint thinner didn't foul the plugs, also inspect all lines and your gas tank for any leaks caused by the highly corrosive nature of paint thinner.
as for your fuel filter, its a simple swap to a new one (comparable to a oil filter) except under pressure. hope that helps
-Devin
Engines hate me... thats why they commit suicide
GreenMadness is offline
Old 09-02-2006, 08:08 PM   #5
dsyple
-Devin
no shyt....allright though...thanx for that....one more thing......after i used paint thinner my gas guage isn't working anymore!what can cause that!!my spark plug becam dark dirty red looking....i guess it late combustion...
dsyple is offline
Old 09-02-2006, 08:13 PM   #6
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
there is a drain plug on the gas tank, however it seems to late for that.
you may have eaten the seals on you fuel injectors causing them to leak and use excess fuel, but who knows. later.
Avoiding dirt at all costs
TypeG is offline
Old 09-02-2006, 08:14 PM   #7
IBCNYA
IBCNYA is cool... so far.
Send a message via Yahoo to IBCNYA
HeHe
IBCNYA is offline
Old 09-02-2006, 10:02 PM   #8
dsyple
leaking?i know i have no leaks in my fuel system or my injectors because i don't have any sign of gas odor...or i don't see a sign of my fuel injectors leaking...even when i start the car and look if im leaking any fuel in my car none.....how do i know if it's leaking...does it leak internally?
dsyple is offline
Old 09-02-2006, 11:45 PM   #9
KillerCam282
KillerCam282 is cool... so far.
Send a message via AIM to KillerCam282
A couple questions:
What is the ratio of gas to paint thinner?
And is the paint thinner Acetone?
KillerCam282 is offline
Old 09-03-2006, 12:16 AM   #10
Ralphie
Stalker
Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed.
damn thats fucked up on your brothers part...i would have knocked him out.....
you should fix your sig block!
Ralphie is offline
Old 09-03-2006, 06:37 AM   #11
Akira_kj
Akira_kj is cool... so far.
Keep adding gas if it still runs, Every gas station you pass if your still driving it you should add more. This will make the ratio or gas to thinner lower and lower tell its so low it dosnt matter. Whatever damage is done was done already. If you cant empty the tank then "thin" out the thinner as best you can and THEN start replacing fuel filters and keep working your way up to more expencive parts untell the problem is fixed. Otherwise your just exposing any replacement parts to the issue that caused the original to fail.
Most fuel filters you can just remove and blow on one end... if you can get air thru you know its not cloged... I dont know the chemical makeup of the paint thinner added to your gas but it might not be as bad for the system as you might think.. the bad part would be what it has knocked loose so to speak. It might react with sealents in the gas tank or injectors and send that stuff thru the motor. -=[
I cant Slam further. The ground refuses to get any lower.
Akira_kj is offline
Old 09-03-2006, 12:07 PM   #12
Stealthman80
Stealthman80 is cool... so far.
you know whats funny? fuel injector clear is pretty much paint thinner isnt it, it sure smells like it
My Members Ride Page
Stealthman80 is offline
Old 09-03-2006, 02:58 PM   #13
cb7_Rocky
cb7_Rocky is cool... so far.
Send a message via AIM to cb7_Rocky Send a message via MSN to cb7_Rocky Send a message via Yahoo to cb7_Rocky
why was there paint thinner mix in there in the frist place?
I Got my Accord, My girl has a I-roc Z ...how is this fair???
cb7_Rocky is offline
Old 09-03-2006, 03:28 PM   #14
KillerCam282
There was an article in SCC years ago about how to make your own race gas. However, the paint thinner they used was toluene.
Old 09-03-2006, 03:42 PM   #15
JDM_EJ
JDM_EJ is cool... so far.
F'd Up Beyond All Repair
My Ongoing CB7 Project
JDM_EJ is offline
Old 09-03-2006, 05:04 PM   #16
cb7_Rocky
Really?. Never herd of that...wont thinner ruin your motor cause it's thining out all the oil
Old 09-03-2006, 05:18 PM   #17
Sector8Customz
Sector8Customz is cool... so far.
my buddy mixes a type of paint thinner half and half with pump gas and boosts his octane to over a 100 with no damage to the vehicle i've also used his stuff when racing...However I didn't catch what kind of paint thinner.
I look...You look
I rev...You rev
I win...You lose
vspooled
Sector8Customz is offline
Old 09-03-2006, 05:52 PM   #18
cb7_Rocky
wow i get smarter everyday DEE DEE DEE!! lol
Old 09-05-2006, 07:48 AM   #19
dsyple
no shyt.....so it has to be a certain painthinner....but if u boost up ur octane rating to over a hundred isn't that bad.....cause ur running to rich....but yeah...thanx for all the help i finally got it fix by just having a full tank of gas....i really appreciate it....
dsyple is offline
Old 09-05-2006, 07:53 AM   #20
CustomLowz
Hung Chow
CustomLowz is cool... so far.
Send a message via AIM to CustomLowz
Glad there was no REAL bad damage.
CustomLowz is offline
Closed Thread
