ok my abs light has been on for months. So today i took the tire off and what u know the tire chewed at the wire. So i cut the bad part out and spiced it all back together. I took the + off the battery for like 5mins but the light still stays on. I checked all the abs fuses in the abs box there fine. I see theres a relay how can i check that. Also, any other problems that u think could keep the light on?
abs insight
Originally posted by deckedaThe light itself should tell you by the number of blinks ... provided you jump the service connector, just like when checking for CEL codes. I'd start there.
off the top of my head, that should mean one of the front sensors is bad. ill double check when i get home.
Originally posted by pretty_ricky302ok the wires that i put back together came apart. Put them back together now the light is off, one problem down to many to count left
