Old 09-06-2006, 07:12 PM   #1
Mangudai
Mangudai is cool... so far.
Difference between the D4,D3,D2,D1?
I think I remember being told you use a certain one when you are going up a hill.
Mangudai is offline   Reply With Quote
Old 09-06-2006, 07:22 PM   #2
slammed_cb7
slammed_cb7 is cool... so far.
If its an auto tranny you are talking about ( i don't know any other d 1-4s) They are just your gears so if you are crawling really slow up a mega steep hill, you use 1 and high speed cruising on the highway would be D 4 or just D. For in between applications, use in between gears.
slammed_cb7 is offline   Reply With Quote
Old 09-06-2006, 09:30 PM   #3
Leung
Leung is someone to admire Leung is someone to admire Leung is someone to admire
a 5spd is more fun going up a hill though.
Leung is offline   Reply With Quote
Old 09-06-2006, 09:34 PM   #4
MikeW
Master Of Posting Nothing
MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock!
Send a message via Yahoo to MikeW
^yeah, especially if youre stopped at the top of it
D4 is the regular driving gear equivalent to 4th(or 5th) gear in an MT. It allows the car to shift through all gears. D3 only allows shiftage to 3rd gear. Now 2 and 1 are for uphill and down hill. i believe 2nd is for downhill cuz its low speeds but high rpms' and 1st is for uphill....i think i could be wrong. But if you have an AT and an awsome exhaust(like i have) you slow to about 45 or 50 and drop it into 2..its super loud and has that MT "top-o-the gear" sound
KeepinItClean | EnviousFilms | NoBigDeal | YET2BSCENE | . ` ' / . | click here.
Originally Posted by Jarrett View Post
MikeW is offline   Reply With Quote
Old 09-06-2006, 09:39 PM   #5
VtecAbuser
VtecAbuser is cool... so far.
just put it in drive and hit the gas. but i wouldnt know about hills with a MT im from new orleans the only hills we have here are levees and even they arent very tall and you cant drive on them
92 Accord LX coupe
JDM H22A w/lsd
I.H.E <nuthin to pricey
stage3 dual friction CF clutch
fuel pressure regulator
tokico blues all around
eibach SL's in front/PK in back
16'' Konig Holes wrapped in Kuhmo 712's
Powerslot rotors in front w/ebc pads
VtecAbuser is offline   Reply With Quote
Old 09-06-2006, 11:08 PM   #6
owequitit
owequitit is very helpful owequitit is very helpful owequitit is very helpful
Send a message via AIM to owequitit
D4 - allows the tranny to use all four foward gears at its discretion.
D3 - basically the same as D4 except that it can only use gears 1,2 and 3. This mode prevents if from using 4th gear. Even once the car hits redline.
2 - This locks the car into second gear only. It will start out in 2nd gear and stay there until you shift it out of 2. This is good in slippery conditions where 1st gear would ordinarily spin the tires.
1 - This locks the car in 1st gear only. Can be used if you need to keep it in first for some reason, or when "manual" shifting the auto tranny. It can't shift out of first gear until you move the shift lever to some other setting.
owequitit is offline   Reply With Quote
Old 09-07-2006, 01:30 AM   #7
92acc
92acc is cool... so far.
brilliant,
i have an auto
does anyone always tend to spin one tire more than the other???
92acc is offline   Reply With Quote
Old 09-07-2006, 02:38 AM   #8
MikeW
No...i used 2nd form time to time, but i never do that shift thing. its either 2nd or D4, lol. I use 2nd and occassionally 1st in the snow
Old 09-07-2006, 02:45 AM   #9
Caution
Caution is cool... so far.
he's got the point......d4 is 3sp automatic with the 4th speed as overdrive....
d2 is for down hill and d1 is for up hill.....d1 is for really steep up hill where you would need the torque of the motor to pull u up and over......were d2 is for down hill were you dont want the car to roll down in the hill to fast in gear....it slows the car down a bit.....but yah, simple
Caution is offline   Reply With Quote
Old 09-07-2006, 03:58 AM   #10
Akira_kj
Akira_kj is cool... so far.
EH, those gears are speed rated aswell. The original owners Manual has a nice breakdown INCLUDING the max speed you should travel in the d1,d2, and d3 setting. What Ive heard so far sounds like the correct usage, but if you realy want I can go dig the manual outta my accord. I wouldnt push the speeds in those lower gears.
I cant Slam further. The ground refuses to get any lower.
Akira_kj is offline   Reply With Quote
Old 09-07-2006, 12:11 PM   #11
owequitit
The gears aren't really speed rated, at least not in terms of those speeds listed in the owners manual. Those recommendations in the owners manual are simply there to help insure that Honda is covered if you do something stupid.
The tranny is perfectly capable of rev limit shifts in every single gear. So is the engine.
Old 09-07-2006, 02:47 PM   #12
Kurobei
Kurobei is cool... so far.
Originally Posted by 92acc
brilliant,
i have an auto
Racing or flooring my auto yes, uness you have LSD which wasn't equipped on our US motors stock. A LSD helps even out the power transfered to the wheels and helps eliminate "peg-legging" some people say. Manually shifting my car I usually feel my drivers side wheel grabbing first after a high rpm shift. From a stop and flooring it, I can feel sometimes slippage alternating on both sides but normally the drivers side will grab the ground first b4 the passenger catches up.
I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?
"I am the Yakuza CB7!"
'92 Accord Sedan SiR
Kurobei is offline   Reply With Quote
Old 09-07-2006, 02:56 PM   #13
K2e2vin
K2e2vin is cool... so far.
The "speeds" are really for mountain driving; save your brakes, allows you to make use of engine braking.
-Kevin
1988 Honda Civi- D15B VTEC Dac Biet, my "race car"
1992 Honda Accord LX: DD until I finish school
K2e2vin is offline   Reply With Quote
Old 09-07-2006, 06:41 PM   #14
Keleka
Keleka is cool... so far.
I dont know about if it locks your gears to what you have it set to, If i can remember, whenever i was in D2 and started to redline, it would automatically shift into 3rd. I think its a safety feature..not sure though
Keleka is offline   Reply With Quote
Old 09-07-2006, 06:54 PM   #15
owequitit
It locks it into the gear you have selected if it is set in 1 or 2. It will not upshift, it will not downshift.
It will bounce off of the rev limit all day long if you so choose.
One of the nice things about Honda. They still believe in driver control, even if they are stupid.
The rev limit is already a safety net anyway.
