Go Back   CB7Tuner Forums > Site Features > DIYs
Thread Tools Rating: Thread Rating: 62 votes, 4.77 average. Display Modes
Old 10-13-2006, 10:47 PM   #1
djcaz_aom
djcaz_aom seems to have made some friends!
EXT: A Complete USDM Black Housing DIY W/ PICS!!! (56K Be Warned!!!)
90-93 Accord USDM Black Housing Headlight DIY
- Follow the link below to do a projector retrofit after black housing your headlights.-
*Link to Morimoto Retrofit
Materials Needed:
Flat Black spray paint (High-temp, BBQ paint or automotive engine enamel works best)
Stained Glass Yellow spray paint (Krylon)
Name Brand Masking Tape (Preferably Blue)
Silicone Sealant (Clear works fine)
Towel
Oven Mitts (Optional)
WD-40
Tools Needed:
Metric socket set
Phillips Screwdriver
Flat Head Screwdriver
Assorted Open-end Wrenches (Metric)
Clamps
Pliers
Razor Blade, or Utility Knife, like an Exacto
Oven
***If you find this thread helpful, please rate it.***
1. Remove the side marker retaining screw. Pull out the marker and unplug the bulb connector.
2. Remove the grill. It is held in place by five screws along the top.
3. One is hidden in front of the latch
4. Use a flat-head screwdriver to push down on the retaining clips that attach the grill to the bumper (one on each end, looking from the front), and remove the grill.
5. Remove the two bumper retaining nuts (one on the left, one on the right) located behind the headlights, on top of the frame.
6. Remove the two plastic retaining clips from the underside of the bumper.
7. Remove the left and right bumper turn signals.
8. Remove the four bumper retaining bolts (two on each side) located just behind the turn signal recesses. Lift the bumper, then slide it forward, and remove it. Set it down some place soft, as not to scratch it up.
9. Remove the five headlight mounting bolts. Two are on the radiator support;
10. One on the side;
11. And two below the headlight.
djcaz_aom is offline   Reply With Quote
Old 10-13-2006, 10:49 PM   #2
djcaz_aom
12. Separate the headlights from the headlight brackets. Remove the two screws for the horizontal adjuster.
13. Apply lots of WD-40 to these two screws, as they are actually bolts and are on there tight. You don’t want to strip them.
14. Remove the two screws for the vertical adjuster.
15. Remove the three screws for the pivot point.
16. Remove this water drain;
17. And this one as well. This one has one screw holding it in place.
18. Pre-heat the oven to 225 degrees F. Remove the 5 metal retaining clips. Place one headlight assembly in the oven for 12-15 minutes.
19. Using a towel and/ or oven mitts, remove the headlight assembly from the oven and place the other one in. Use extreme caution as the headlights will be very hot. Slowly pry the front of the assembly off with a flat-head screwdriver. If the adhesive gets too difficult to handle, stick the assembly back in the oven, to soften it up. You may find that you won't even need the screwdriver at all.
20. Just like magic, it’s off. Do the same for the other headlight. Allow to cool, before moving on.
21. After the housings have cooled, you will be ready to paint. You will be painting every thing except the two half-moon reflectors to the rear of the housing. Remove the lo-beam cap. (one screw secures it. You may choose to paint it as well.) Mask off the half-moon reflective surfaces. Be sure to take your time. The more time you take on this step. The better end result you will get. Note: Be sure to press down on the edges of the masking tape to prevent the paint from seeping through. You may choose to sand the area to be painted with 400-Grit sand paper.
22. Apply 5-6 thin coats of paint to the housings. Resist the urge to do this part quickly, by applying heavy coats. You run the risk of the paint running.
23. The painted reflector housing, after being placed in the oven for 10 minutes (At 225 degrees) to allow the paint to cure.
24. A side by side comparison.
Old 10-13-2006, 10:57 PM   #3
djcaz_aom
25. *Optional; If you want the JDM Yellow High Beam Look, then apply two light coats of The yellow stained glass paint to the high beam side only. Place in the oven @ 225 degrees for 5-8 minutes so the stained glass paint will cure properly. (Funny I learned how to stained glass in elementary school in arts and crafts; never thought I would use this trick ever again.)
26. Apply a small amount of silicone to the outer edges of the housing and put the two halves back together. Put the metal clips in place, and insert the headlight assembly in the oven for 10 minutes at 225 degrees. Allow to cool. Remount them to the car in reverse order.
27. Nice.
With yellow High Beam.
28. Low-Beam.
29. High-Beam.
Old 10-13-2006, 10:58 PM   #4
HondaGuy1212
HondaGuy1212 is cool... so far.
Awesome Diy good pics too thanks
HondaGuy1212 is offline   Reply With Quote
Old 10-13-2006, 11:02 PM   #5
Weezo182
Weezo182 is cool... so far.
Send a message via AIM to Weezo182
great wright up
1966 Chevy Nova
1974 Super Beetle
2012 Ford Super Cobra Jet
2004 Honda Element
2004 Honda Ruckus
2003 Honda Ruckus
www.weezoonline.com
www.facebook.com/weezoonline
Weezo182 is offline   Reply With Quote
Old 10-13-2006, 11:08 PM   #6
djcaz_aom
Thanks guys.
Old 10-14-2006, 01:52 AM   #7
redlineCB7
redlineCB7 is cool... so far.
Send a message via AIM to redlineCB7
yo thats very very very helpful
"it's gettin there"
redlineCB7 is offline   Reply With Quote
Old 10-14-2006, 06:52 AM   #8
Sobeman81
Sobeman81 may have said something they shouldn't have...
Send a message via AIM to Sobeman81 Send a message via Yahoo to Sobeman81
Great Job on the write up and final result on it man..i have started my project..just got lazy and its sitting there..one of these days i tell ya..lol..even got the blackhoused corner lights ready to go with it..but like i said..got lazy cuz of skool and now work,..itll be on there soon enuff..pe@ce
Sobeman81 is offline   Reply With Quote
Old 10-14-2006, 08:17 AM   #9
civic_90_08
civic_90_08 is cool... so far.
Send a message via AIM to civic_90_08 Send a message via Yahoo to civic_90_08
Well somebitch. I didnt know it was that easy...Nice write up, it puts everything into perspective. Great job on the headlights bro....I like
-Jordan
I ♥/Miss My Coupe
civic_90_08 is offline   Reply With Quote
Old 10-14-2006, 09:57 AM   #10
Shadow1
MidAtlantic Regional Mod
Shadow1 seems to have made some friends!
Send a message via Yahoo to Shadow1
could you use a heat gun on the headlights instead? i dont think my dad would be to happy to wake up or come home with head lights in his oven.
_______
UGS Owner/Member #1(On Vacation)
2001 Accord EX: New car Acquired...
Shadow1 is offline   Reply With Quote
Old 10-14-2006, 11:31 AM   #11
djcaz_aom
Thanks for the good cmments. It inspires me to make more DIYs.
"could you use a heat gun on the headlights instead? "
It's possible; though I've never tried it. Heat is heat. Try it out and let me know.
Old 10-14-2006, 11:45 AM   #12
cp[mike]
cp[mike] seems to have made some friends! cp[mike] seems to have made some friends!
very nice... i added it to the sticky.
Old 10-14-2006, 12:07 PM   #13
djcaz_aom
Thanks cp[mike]. I'm working on one for the corners as well.
Old 10-14-2006, 01:43 PM   #14
Shadow1
keep if up man. ill be trying this next week when i get my paycheck. holla. dropped suspension. blackhoused headlights. now all i need is some red/clear tails. then ill be happy. lmao
_______
Old 10-14-2006, 02:38 PM   #15
wrichards2005
wrichards2005 is cool... so far.
Send a message via AIM to wrichards2005 Send a message via MSN to wrichards2005
Good DIY man, but one piece of advice... You don't have to take off the headlight adjusters.
wrichards2005 is offline   Reply With Quote
Old 10-14-2006, 03:18 PM   #16
deckeda
deckeda is cool... so far.
For those that haven't removed their corners before, you pull FORWARD on the light housing. It may give a "snap" sound. If you pull more towards you (sort of off to the side of the car) you'll break the tab on the housing. It's unfortunately one of those things that's obvious only after you've done it.
deckeda is offline   Reply With Quote
Old 10-16-2006, 04:23 PM   #17
John Conner18
John Conner18 is cool... so far.
Send a message via MSN to John Conner18
sounds like my dad, wait just the though of me working on my honda(to him) would piss him off
My Ride17.34 @ 78mph with 260k on her
John Conner18 is offline   Reply With Quote
Old 10-16-2006, 06:22 PM   #18
h22sparkle
h22sparkle is cool... so far.
Very nice I like whats cookin in the kitchen smells good if your really good
I dont know it seems to me theres alot of posers on here or lames that like to buy other peoples built cars so sad. As for me im one of a kind the fastest of my own kind.
h22sparkle is offline   Reply With Quote
Old 10-16-2006, 07:37 PM   #19
nostringz
nostringz is cool... so far.
i was wondering... could i do this same DIY to my bumper signal lamps since they are clear too?
Be Clean
nostringz is offline   Reply With Quote
Old 10-16-2006, 07:43 PM   #20
GunRunner
GunRunner seems to have made some friends!
they already make blackhoused bumper lights..they are all over ebay
My Black Love NA H22 233whp 185wtq
My White Slut F22a6 Daily Driver
GunRunner is offline   Reply With Quote
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
