does any one know if nsx calipers fit the cb7. i no pads need to be nsx but does the rotor need to be changed as well?
Nsx calipers on a cb7
i dont think anyone has ever done it. i know they fit on the preludes 5-lug, which is the same as the ITR 5-lug. so it could be possible
EDIT: looks like soy's got it covered.Last edited by Accord R33; 11-07-2006, 02:10 PM.
Something like nsx is similar to the legend calipers and such but just lighter or something forgot.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
they should be dual piston if i remember correctly, and will mount if you have the matching brackets and larger wagon rotors.
now which car was it that had trailing edge calipers instead of leading edge? were they the legend or NSX? usc provided a beautiful writeup about it.
edit: found it http://www.cb7tuner.com/vbb/showthre...egend+calipers sure its technically about legend calipers but read it in full before saying boo.Last edited by cp[mike]; 11-07-2006, 03:34 PM.
Like others said, it can be done.
You will need 11.2" rotors, and the correct caliper bracket. I believe the part # is 25T. It is the same bracket that is used on the ITR, the Prelude VTEC, the Accord Wagon, the Legend GS and the NSX.
You can get them from Autozone by ordering brackets for an ITR. They don't have it in their systems as the ITR though, and I can't remember the part number. Sorry.
Also, you can fit your existing hubs with wagon rotors, or you can do the rotor over hub conversion, and use any number of other 11.2" Honda rotors (ITR, Prelude VTEC, 1998-2002 Accord V6 etc.)
