Materials Needed:
(2) 3-inch latches, regular size latches will work fine, heavy duty ones just make for more work no need to kill your self.
(2) Triangular hinges
(Approx. 15) Tapered head screws, the ones that could be flushed into the hinges.
1. With trunk open, mark the trunk lid at the top of the stock brackets.
2. Remove your trunk lid slowly by unbolting about 4 bolts. Please do not remove the stock brackets, only the trunk lid.
3. Attach the flat side of the enclosed hinge to trunk lid below the mark, with the bottom of the hinge facing down.
4. Next you will have to bend hinges. Take the 2 hinges and bend one side at a 90-degree angle.
5. With help reattach trunk lid to stock brackets using curved hinge. Be sure to pre-drill all holes before mounting new hinge. This hinge will create the fold down effect.
6. Connect latches about 2 inches from the bottom of the trunk lid. Be sure they are mounted on the inside of the stock brackets.
7. Mark a spot on the stock bracket to drill to allow the latches to latch. Be sure the latch will latch tightly. If it doesn't latch tightly you may have to replace the stock bottom bolts each time you want to fold down your trunk lid.
Your down!!!!!!!
(optional: a prop rod maybe needed I plane on using hood shocks just havent got around to it yet)
Your down!!!!!!!
