Hi all,
I'm currently installing a remote car starter w/ a door locking feature. Before someone starts to flame me to search, trust me I did! I've searched extensively through the12volts.com, this site, my manual etc. I've seen the car's wiring diagram etc.
For power door lock/unlock, do I need a relay or is it as simple as tapping the unlock and lock wires on the car? The locks are negative (-) triggered 250 mA. The remote starter module outputs 500 mA negative (-) trigger. Since the module outputs 250 mA more, are resistors needed to lower the mA from 500 to 250? Also, to avoid feedback from the circuit are diodes required too?
I am also not sure about the ignition wires. I found out that there are 2 ignition wires on the CB7. My module has 2 outputs for each ignition wire. Is it as simple as tapping those wires too?
I would love to do a DIY since I couldn't find a specific how-to on this site. Most say its relatively easy to do, but its the relays/diodes/resistors I'm not too sure about. I would take it in for someone to do, but then I wouldn't be able to write a DIY
Thanks.
Thanks.
