TSX Retrofit DIY
Click HERE for the finished video DEMO
After much brainstorming and research on HIDPlanet.com, I finally decided to tackle a retrofit project of my own. I decided to use the Acura TSX projectors for their output, manageable size, and affordability. My retrofit headlights are USDM pieces that I purchased from another member (thanks 93cbh22), because I like the look of the US pieces and love the affordability. I have about 60+ hours into this project to get it done right, so don’t expect a weekend deal. On a scale of 1-10 for difficulty I give this retrofit about an 8, it was very time consuming but completely worth the end result.
I purchased my TSX projectors off of eBay for $150…..I’ve seen them more and less expensive and trust me they’re worth every penny. The TSX projectors require the use of a D2S based HID bulb, and applicable ballast for each side. I ended up purchasing 2 used Philips Generation III ballasts locally for about $200. These ballasts are stock OE equipment on many new Audis. Also purchased a pair of new Philips D2S 4300k bulbs (PN 85122) for my application, this is the best color/temperature bulb for the application as it produces the most usable light. This are also the factory equipt bulbs in the TSX projectors.
The infamous TSX color mod
Color modding can be completed on a variety of HID projectors, and the TSX is one of the easiest to do this on. Color modding simply increases the area of color shift at the projectors cutoff (where light ends/begins) point. It requires that you shim the reflector bowl (rear of projector) away from the lense housing (front of projector) with 2-4 #8 washers at the BOTTOM and not the top. Below is a picture that shows how the color mod is completed and the results of a proper color mod.
TSX projectors
The bulbs (Philips D2S 4300k)
Reflector bowl and internal cutoff shield w/righthand step
Color mod
Color at cutoff
TSX dimensionsAcura TSX Low Beam (Stanley):
Diameter = 71.05mm
Height = 85.30mm
Width = 120.80mm
Length = 156.45mm
Length(seat of the lens to mounting holes) = 42.00mm
Length(mounting holes to end of bulb) = 96.95mm
Width(between top mounting holes) = 100.45mm
Width(between bottom mounting holes) = 103.45mm
Height(between mounting holes) = 41.50mm
(referenced HIDPlanet for dimensions)
Where to begin
Getting started initially was difficult for me because I hadn’t tackled a retrofit project before. Studying up on other peoples retrofit projects provided me with a more enhanced knowledge base to begin with, and increased my chances for a proper and LEGAL retrofit result. I soon learned that you can never know too much about lighting……
Getting your hands dirty
The first order of business was determining just how to mount the projectors. The hardware needs to be solid, but also allow some room for adjustability. There are multiple factors to consider when mounting projectors in ANY headlight:
1)Vertical adjustment of the projector
2)Horizontal adjustment of the projector
3)Rotational adjustment of the projector
4)Clearance for retrofit re-install into your vehicle
5)Providing a tight, weatherproof seal for the modified housings (avoiding fog/condensation issues)
TSX projectors
Color mod
Color at cutoff
Diameter = 71.05mm
Height = 85.30mm
Width = 120.80mm
Length = 156.45mm
Where to begin
