Old 02-16-2007, 01:11 PM   #1
Shehzada
Shehzada is cool... so far.
Door Lock Vandalized - Key Does Not Work
Hey guys,
My door lock, thanks to some prick out there, was tampered with and is vandalized. The reason I say that is cuz one morning my key would not go in the driver's side but the passenger side works fine.
I tried pushing it , shoving it in, but the key won't go in. Is there an easy way to access the lock to inspect it. I've removed the door panels before and they're fairly easy to take off.
Or does someone suggest I try something else first.
Thank you.
1992 Accord Coupe 5-Speed
Shehzada is offline   Reply With Quote
Old 02-16-2007, 01:15 PM   #2
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
if you pull the door panel off and the window up, you can remove the door handle by removing the two 10mm bolts on either side of the inside of the handle, and prying the bar out of the plastic clip on the back of the lock. with the handle removed, you can pull the lock out and pull it apart...
- 1993 Accord SE - Gold coupe
- 1999 CR-V EX - Daily driver
Old 02-16-2007, 01:24 PM   #3
simactive
simactive is cool... so far.
You could try to open the flap up and shine a light from a LED light or something then peer in, i dunno if u want to do that and get a rough idea on whats going on inside the lock. if u got a photo viewer thing then you could mess about with that. i dunno if thats more work or less. goodluck.
but mike did u weld the Piston and Valve together in your engine?!!?! lolz!
1990 Accord EX -Stock to no beyond
Originally Posted by yeamans17
you'd better soak the nuts in pb blaster, otherwise you'll snap them off
"Be who you are and say what you feel, because those who matter don't mind, and those that mind, don't matter" - Dr.Susses
Vouch - | gloryaccordy | aznkid.com |
simactive is offline   Reply With Quote
Old 02-16-2007, 11:59 PM   #4
Shehzada
Thanks for those tips guys. It's a little bit cold outside where I am (Mike can attest to what I'm talking about), so I'm gonna find a garage where I can temporarily park it and check the insides out.
So Mike, how have u been? Hope all is well. Just so you know, I'm a firm believer in the copper gasket you showed me once.
Old 02-17-2007, 12:05 AM   #5
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
if the lock is broken, you can always upgrade to the security locks. later.
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 02-17-2007, 12:07 AM   #6
SMseagren83
Accord of the Month: October 2007
SMseagren83 is cool... so far.
Send a message via AIM to SMseagren83 Send a message via MSN to SMseagren83
sounds like a new lock cylinder may be needed. not too expensive from honda.
F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
SMseagren83 is offline   Reply With Quote
Old 02-17-2007, 01:19 AM   #7
ampzoner
ampzoner is cool... so far.
Send a message via AIM to ampzoner Send a message via Yahoo to ampzoner
Originally Posted by Shehzada
Hey guys,
Thank you.
i would invest in some security people dont just go around messing with car door locks unless they tryin to get in some ones out for your car
ampzoner is offline   Reply With Quote
Old 02-17-2007, 09:37 AM   #8
doylna
doylna is cool... so far.
If you'd had the snow, rain and sleet in NYC that everyone else has had in NY, then there may be a bit of water in your lock that's frozen. I believe the same thing has happened to me. Somehow just enough water has gotten into my lock cylinder that when it's really cold, before the car warms up, I can't open my door.
doylna is offline   Reply With Quote
Old 03-11-2007, 04:50 PM   #9
Shehzada
Update:
The weather finally got warmer and I was real tired of opening the passenger side door and leaning inside to open the driver's door (my power door locks don't work too well )
I followed CP[Mike] directions and it turned out to be a quite easy repair. The door panel was easy and those 2 bolts were pretty accessible. However prying that bar out took some work since I didn't want to damage it.
Once I had the cylinder in my hand, I took it apart. I took out each individual pin and spring and cleaned it with acetone. It was all gunked up with Krazy Glue. I put every thing back together and all went well. I did manage to lose one of those springs that go inside the cylinder, but it didn't affect the functioning.
All in all it took about 2 hours (including the time it soaked in acetone and cleaning) and it was well worth not paying $40 for a new cylinder. Thanks to everyone who replied and to Mike.
Old 03-11-2007, 04:59 PM   #10
casterX
casterX is cool... so far.
good job!
krazy glue eh!! i guess somebody hates you enough to get some glue, get it in your lock and enjoys the sight of you having to open the door through the passener side everytime or it was just some random kid who had nothing else better to do..
casterX is offline   Reply With Quote
Old 03-11-2007, 05:06 PM   #11
Shehzada
I'm positive it was no random act. There's someone who's after my car. A few months ago I found a piece of board with nails sticking out conveniently under my front passenger tire. Luckily I removed it before it did anything. Now, every time before I get in my car, I do a walk around and do a visual inspection.
BTW, if you don't see me posting here for a while, it's not because I fell over the face of this earth.
Old 03-11-2007, 05:26 PM   #12
npor
npor is cool... so far.
Send a message via AIM to npor
you need to find out who it is
and beat some ass.
that's fucked up, tires aren't cheap.
npor is offline   Reply With Quote
Old 03-11-2007, 06:27 PM   #13
jboyce
jboyce is cool... so far.
Send a message via AIM to jboyce
i had someone break in my car once and f up the lock, i had to get keyless entry...which was f'in sweet so yea.
jboyce is offline   Reply With Quote
Old 03-16-2007, 04:18 AM   #14
sackingz123
sackingz123 is cool... so far.
Send a message via AIM to sackingz123
hahhahahah funny shit man.
i would ur bang ur ex in a minute...
sackingz123 is offline   Reply With Quote
