NEW 2.25 piping. Under $90.
    Sup people of cb7 tuner.com this morning i had Gehman's put 2.25 from CAT BACK. and BOY does she sound good. sounds the same jus more throtty SHADOW 1 u gotta get your ass down to that shop. IT is worth the RIDE, and it has twisty roads ull have fun.
    He charged me a total of $83.42, they was cool enough to let me take pics while they was workin on the car.
        F22A in there? Without mods to make use of that wider piping, you won't really benefit from anything larger than 2.25". A good header, some headwork, and a cam will justify that... otherwise, you just lost considerable low end.
          acutally i didnt feel any low end missing the car pulls stronger thru out the gears. i have the f20a sohc motor.
            Oh, ok... the F20A may make decent use of that then... Not sure, since the displacement is smaller than the F22A, but the redline is higher, and the power is greater (suggesting better head flow, I suppose) 2.5" is usually best for the H series swaps.
              Hey 2.5 is good for the H? So i have 2.25 now with my f, when the H goes in (which is very soon btw) do i need to up my piping to 2.5? Will there be a considerable gain from a quarter of an inch?
                hey where are you in pa? lets do a mini meet then. we've got 3 cb7 tuners here.
                miss my turbo cb7
                moved onto volvos. dont know how that happened, just did
                  well the heads the ssame as the f22 motor. but i can upgrade to h23 mani. which i am, i dont wanan go all out on this motor. i jus want h23 mani. good header. 2.25 flex and cat. regrind cam and thats it.
                    Im in READING pa. about 30 min from lancaster hour or so from philly. IF u wanna do a mini meet then fine. let me know. send me a pm
                      nice!! for 90 bux was that at an exhuast shop in ur area
                      current cb 93 10th ann. edition
                      member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
                        yes sir. hes about 30 min away. other shops wanted 140, from cat back other shop wanted 170
                          2.5" is optimal... 2.25" will work, but the H22 makes the power up top... and with a smaller diameter piping, it won't make as much. The gain may not be considerable, but it's worth mentioning.
                            HOw do u feel towards a stock CAT, any cat aftermarket should b better then stock. i found this cat i may get along with 2.25 flex pipe.
                              The stock cat is actually fairly free flowing... however, you may want to get a wider diamter cat, since you've opened up the rest. Might as well get a 2.5" flex pipe, too... and eventually a header with a 2.5" colletor. Any bottleneck in the exhaust system will be a restriction. It's like drinking through a straw while pinching it in the middle.
