I need to buy one for my car, it is running too rich. Where can I find one for my car? I want one which i do not need to modify at all to put on. Basically a direct bolt on fuel pressure regulator for the h22a. Thanks.
.when was the last time you had a tune up???92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
http://www.cb7tuner.com/vbb/showthread.php?t=174586
My tribute page: http://www.cb7tuner.com/vbb/showthread.php?t=70489
If its stock and its running rich you got other problems. Fuel pressure reg aint gonna do shit its just gonna jack your settings if your car aint running right in the first place. Do a tune up, make sure timing is on point. All those effect running rich and crap. Obviously SOMETHING is not burning the mixture so your getting fuel out the pipe. Do those before even buying a regulator and I am using my f22a fpr on my h22a and its just fine.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
what would you suggest i do then? i changed the spark plugs, the spark plug wires, oil has been changed, the filter was replaced, the radiator fluid was changed. the f22a1 o2 sensor was lengthened to fit on the downpipe instead of the exhaust manifold header.Originally posted by NAiL05If its stock and its running rich you got other problems. Fuel pressure reg aint gonna do shit its just gonna jack your settings if your car aint running right in the first place. Do a tune up, make sure timing is on point. All those effect running rich and crap. Obviously SOMETHING is not burning the mixture so your getting fuel out the pipe. Do those before even buying a regulator and I am using my f22a fpr on my h22a and its just fine.
check resistance at the coil. how old is ur O2 sensor....might be time to think about changing that out.F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
