If you lucky, you can go to the junk yard and get a 98+ accord cluster and the pig tail.
ADVANTAGE:
Look nice, and newer
Digital Odometer
Needle glow
Cheaper than a prelude cluster swap
cost no more than $40.00
DISADVANTAGE
Low gas wouldnt go up (unless you figure out what happen)
temp gauge will NOT work (I think it got to do with the wiring)
seat belt light wouldnt show up
dome light only work on driver side (I think it the wire again)
key:
R-[Red] B-[Black] Bl-[Blue] W-[White] Y-[Yellow] O-[OJ] P-[Pink] G-[Green] LG-[Light Green]
90 Accord
Connector A has 10-Pin
Connector B has 18-pin
Connector C has 22-pin
98 accord
Connector A has 14-pin
Connector B has 22-pin
Connector C has 16-Pin
90-93 Accord To 98-02 Accord
A block
A1 R/B Dimmer ----------> B22 R/B
A2 R Dimmer ----------> B10 R
A3
A4 O Speedometer-------> B2 Bl/W
A5 Y Ignition + ----------> B11 Y
A6
A7 Bl Tachdometer ------> B1 BL
A8 B Ground ------------> B16 B
A9
A10
B Block
B1 R/BL High beam ----------> O/W
B2 R/G High beam ----------> R/W
B3 G/Y Turn right -----------> C8 G/Y
B4 Bl/R Bulb Check circuit
B5 Y/R Seat belt ------------> C3 R/BL
B6 Y Ignition + --------------> B11 Y
B7 G/Bl Turn LEft ------------> A14 G/BL
B8 Y/R Oil -------------------> B7 Y/R
B9 R/B connect this to connector A1 on 90 accord
B10 Bl/R ABS ----------------> C10 BL/W
B11 G/R Hand Brake ---------> C14 G/R
B12 Grey or Bl SRS-----------> C9 BL
B13 Black Ground
B14 R Cruise control ---------> A6 BL/B
B15
B16 G/O Check engine -------> B6 G/O
B17 B/Y Charge --------------> B9 B/Y
B18 W/BL charge ------------> B8 W/BL
B19 whoop there is no B19
C Block
C1 G/R passenger dr----------> A7 G
C2 B/W Doom light -----------> A11 W/G
C3
C4 W/G Brake light sensor ----> A10B/W
C5 R Temperature ------------> C2 Y/G
C6 Y
C7 G
C8 G/W P Drive --------------> C15 B/Bl
C9 LG
C10 G/R R Drive --------------> C4 W
C11 G/W R Rear DR ------------> A8 G/W
C12 G/B Trunk light -----------> A9 O
C13 G/Bl Driver dR ------------> A2 G/O
C14 G/Y L rear DR-------------> A1 G/Y
C15 Empty
C16 LG/W D1 drive ------------> C5 Brown
C17 G/Y D2 drive --------------> C7 BL
C18 Y/W Fuel Gauge -----------> C11 Y/B
C19 G/R Low Fuel --------------> C1 LG/R
C20 G/Bl D3 Drive --------------> C6 Pink
C21 G/B D4 drive -------------->C12 G/B
C22 G N Drive---- -------------> C16 R/B
DO THIS AT YOUR OWN RISK! I GOT MOST OF THE STUFF TO WORK, AND I DID THIS IN A MANUAL CAR.
That is sooo messy.
look at This image, you WILL have to cut the part I circle:
The fitment:
as you know it, there is NO screw to hold the cluster.
it fit.
After install the bezel:
ADVANTAGE:
Digital Odometer
Needle glow
DISADVANTAGE
key:
90 Accord
98 accord
A block
A3
A6
A9
A10
B Block
B13 Black Ground
B15
C Block
C3
C6 Y
C7 G
C9 LG
C15 Empty
That is sooo messy.
The fitment:
it fit.
