Go Back   CB7Tuner Forums > Site Features > DIY's
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 07-30-2004, 02:31 AM   #1
ACCORDianate
ACCORDianate is cool... so far.
ENG: F22 Spark Plug Tube Seal Replacement
I've seen many threads these days about "I've got oil all over my #blah spark plug, and the tube is full of oil.". Here's how to take care of it. It should take an hour or two, even with minimal engine experience. This is mostly stolen out of a Hanyne's 90-93 Accord (F22) manual.
You'll need:
- in-lb torque wrench
- ft-lb torque wrench
- rubber hammer
- sockets/ratchet
- screwdriver
- blue high-temp RTV sealant or HondaBond
- plug tube seals, lower plug tube seals, valve cover gasket (AutoZone sells a set by FelPro for $16 that includes all the gaskets/seals you'll need)
- 4 new spark plugs (replace distributor cap/rotor and spark plug wires at your discretion)
Note: The camshaft bearing caps are removed together with the rocker arm assembly. To prevent the opposite end (transaxle end) of the camshaft from popping up (due to timing belt tension) after the assembly is removed, have another able body hold the opposite end of the camshaft down, then reinstall the bearing cap on that end to hold it in place until reassembly (if timing belt remains installed, but is easiest while changing timing belt when there no tension on the cam gear).
Step 1: Remove the valve cover
1- Remove spark plugs.
2- Remove the distributor cap and wires. Be sure to mark which wire goes where for correct intallation.
3- Mark and detach any hoses or wires from the throttle body or valve cover that will interfere with the removal of the valve cover.
4- Wipe off the valve cover the prevent dirt and debris from falling onto the exposed cylinder head or camshaft/valve train assembly.
5- Remove the valve cover (acorn) nuts.
6- Carefully lift off the valve cover and gasket. If the gasket is stuck to the cylinder head, tap it with a rubber mallet to break the seal. Do not pry between the cover and cylinder head or you'll damage the gasket mating surfaces.
Step 2: Position number one piston at Top Dead Center (TDC)
1- Remove the timing mark inspection plug.
2- Place the number one piston (closest to the drivebelt end of the engine) at Top Dead Center (TDC) on the compression stroke.
To do so, rotate the crankshaft pulley clockwise until the timing pointer on the block lines up with the TDC mark on the flywheel. The distributor rotor should be pointing toward the number one spark plug wire terminal on the distributor cap. If it isn't, rotate the engine one complete turn and realign the marks.
Step 3: Rocker arm removal and seal replacement
1- Have an assistant hold down the transaxle end of the camshaft, then loosen the camshaft bearing cap bolts 1/4 turn at at a time. Starting with the #3 cylinder loosen the two exhaust side camshaft bearing cap bolts. Loosen the bolt on the intake side of the assembly behind the spark plug tube. Repeat for #2 cylinder, #4, #1, and then loosen the cam bearing caps at the end #1 cylinder end of the head behind the cam gear. Finally loosen the 2 bolts at the #4 end that are closest to the distributor. DO NOT REMOVE THE BOLTS COMPLETELY FROM ROCKER ASSEMBLY.
2- Lift entire assembly off in one piece. If timing belt is in place, see note above.
3. Lower tube seals will be attached/stuck to the bottom of the rocker assembly. Remove pieces of lower plug tube seals (will probably be in severa pieces). Be sure to remove all remnants of old tube seals from rocker assembly.
4- Replace tube seals.
STEP 4: Rocker arm assembly reassembly
1- Replace rocker assembly.
2- In the reverse order of loosening, tighten rocker assembly bolts. The smaller 6.0 x 1.0 mm bolts need to be torqued to 108 in-lbs, and the larger 8.0 x 1.25mm bolts to 16 ft-lbs.
STEP 5: Adjust valves
1- With the engine still at TDC, the #1 cylinder valve adjustment can bve checked and adjusted. Start with the intake valve clearance. Insert a 0.010-in feeler gauge between the valve stem and rocker arm. Withdraw it, and you should feel a slight drag. If there's no drag or a heavy drag, loosen the adjuster nut and back off the adjuster screw. Carefully tighten the adjuster screw until you can feel a slight drag on the feeler gauge as you withdraw it.
2- Hold the adjuster screw with a screwdriver (to keep it from turning) and tighten the locknut. Recheck the clearance to make sure it hasn't changed. Repeat the procedure in this tep and the previous step on theother intake valve, then the two exhaust valves. For the exhaust valves, use a 0.012-in feeler gauge.
3- Rotate the crankshaft pulley 180-degrees counterclockwise (the cam pulley will turn 90-degrees) until the #3 cylinder is at TDC. With the #3 cylinder at TDC, the UP mark on the camshaft sprocket should be pointed at the exhaust side (nine O'clock position) and the distributor rotor should point at the #3 spark plug wire terminal. Check and adjust the #3 cylinder valves.
4- Rotate the crankshaft pulley 180-degrees counterclockwise until the #4 cylinder is at TDC. With the #4 cylinder at TDC, the UP mark on the camshaft sprocket should be pointed straight down, and the distributor rotor should point at the #4 spark plug wire terminal. Check and adjust the #4 cylinder valves.
5- Rotate the crankshaft pulley 180-degrees counterclockwise to bring the #2 cylinder to TDC. With the #2 cylinder at TDC, the UP mark on the camshaft sprocket should be pointed to the intake side (three O'clock position), and the distributor rotor should point at the #2 spark plug wire terminal. Check and adjust the #2 cylinder valves.
STEP 6: Put it all back together
1- Replace upper plug seals.
2- Replace valve cover gasket, and use HondaBond or high-temp blue RTV sealant to make sure there's no leaks. Let the RTV site for about 5 minutes to harden up before putting valve cover back on head. Torque the acorn nuts to 84 in-lbs. DO NOT overtighten these acorn nuts, as they are easy to split. If they break, you have a trip to the parts store in your immediate future in another vehicle.
3- Reconnect any hoses or wires from the throttle body or valve cover that previously disconnected.
4- Replace spark plugs with new NGK spark plugs (I've been using Autolite with no problems, however).
5- Reinstall distributor cap and plug wires.
I'm sure I've left some details out, but the bulk of the matter is here. I'm sure someone will chime in with something that I missed or overlooked, and I welcome all suggestions and/or corrections.
ACCORDianate is offline   Reply With Quote
Old 08-19-2004, 10:55 AM   #2
ACCORDianate
Okay, here's what I came up with:
This pic is showing the rocker arm assembly already taken off.
1 is where the lower tube seals go.
2 is the oil journal that usually causes the #2 plug tube to leak
3 is the cam seal
Now notice on the next pic, it shows:
1 is where the replacement tube seals go
2 are all the old plug tube seals that came off the rocker assembly. They shred very easily and will come out in a million little pieces. carefully use a flathead screwdriver to get the old pieces out. be thorough or the new seals won't fit right.
3 is the oil journal that causes the #2 plug tube to leak
*notice how the bolts are still in the rocker assembly so the same bolts go back into the same holes*
Hope that helps out some, guys.
Old 09-07-2004, 01:16 AM   #3
HondaFan81
Moderator
HondaFan81 is cool... so far.
9/6/04 update:
Started this project today and have been taking pics of it, I'll have it done by tomorrow seeing that I had to adjust my cam timing as well cuz the f**kers at the Honda dealer (which we never had issues with) had the timing off, no wonder my car would dog so much from 5500 RPMs and up. BLEH!
CISCO - NA F22AX Enthusiast
"Common sense is the least common of the senses." ~ My Grandfather
HondaFan81 For Sale Parts (EVERYTHING HAS PHOTOS!!)
HondaFan81 is offline   Reply With Quote
Old 01-16-2005, 02:07 AM   #4
HondaFan81
Moderator
Step # 1
Label spark plug boots, not to mix them up and make installation easier. Remove spark plug boots.
Old 01-16-2005, 02:25 AM   #5
HondaFan81
Moderator
Step # 2
Label spark plug wires at the distributor end to make installation easier and have no mix ups. Remove spark plug wires from distributor cap.
Old 01-16-2005, 02:28 AM   #6
HondaFan81
Moderator
Step # 3
Remove the 4 acorn nuts & washer grommets on the valve cover to remove it, these are 10mm. Torque specs are 84 in-lbs. Remove the valve cover ground wire as well that's near oil cap.
Old 01-16-2005, 02:31 AM   #7
HondaFan81
Moderator
Step # 4
Be sure to label the distributor cap terminals as well, in reference to the wires. Remove only the top screw from the distributor housing so you can remove the rocker arm assembly later.
Old 01-16-2005, 02:32 AM   #8
HondaFan81
Moderator
Step # 5
Overall view of the valvetrain after removal of the valve cover. Take the time now to loosen all the intake & exhaust valve lash nuts. Reason for doing this is so that when you install the rocker arm assembly, you do not put instant valve pressure on them. Makes installation of the rocker arm assembly easier.
Old 01-16-2005, 02:34 AM   #9
HondaFan81
Moderator
Step # 6
Before removing the rocker arm assembly, I suggest removing the timing belt off the camshaft gear. This will help relieve the force pulling down on the camshaft gear end. Paint a line from the cam gear to the timing belt so you know how to realign the two parts later so your cam timing is not out synchronization. To remove the timing belt, on the cam gear end you will find an adjustment nut (14mm), which you want to loosen 1 full turn, push the timing belt on intake side inward, then retighten the adjustment nut snug again. This will loosen the timing belt enough for you to slip it off the cam gear (after your mark the belt to the gear for later reference). It may still take some force to remove the belt.
Loosen all the rocker arm assembly bolts in the REVERSE order of the "Tightening Torque Sequence" in post #43 further down in this thread. Do NOT remove the bolts after they are fully loosened up, just leave them in place or the rocker arm assembly will spring apart. Notice the bolts are all loosened, but kept in place in the photo below.
Old 01-16-2005, 02:39 AM   #10
HondaFan81
Moderator
Step # 7
Rocker arm assembly is removed, maintain bolts in place.
Old 01-16-2005, 02:41 AM   #11
HondaFan81
Moderator
Step # 8
Photo of under the rocker arm assembly where you can see the lower spark plug tube O-rings, these are the old ones that leaked and caused oil to get into the spark plug tubes. Cylinder # 2 O-ring usually is the first to go because it's next to an oil passageway.
Old 01-16-2005, 02:45 AM   #12
HondaFan81
Moderator
New parts photos
Photos of all the new O-rings, gasket, seals, etc for all seals under the valve cover. Also included are new NGK spark plugs because I did not want to reuse the old oil covered ones.
Old 01-16-2005, 02:46 AM   #13
HondaFan81
Moderator
more new part photos
Couple more new parts photos...
Old 01-16-2005, 02:47 AM   #14
HondaFan81
Moderator
Step # 9
Photos of old upper tube seals on the valve cover, you can choose to clean the valve cover as well at this point before installing the new seals.
Old 01-16-2005, 02:48 AM   #15
HondaFan81
Moderator
Step # 10
New upper tube seals on the valve cover installed...
Old 01-16-2005, 02:53 AM   #16
HondaFan81
Moderator
Step # 11
Photo of new lower tube seals or O-rings installed. Be careful not to encounter any sharp metal edges when installing these, as to not slit them. Put a light coat of oil on all four O-rings before installing them.
** EDIT - There is NO NEED for Hondabond or any RTV/silicone on these O-rings. It was a false alarm on my previous comment with oil seeping into cylinder #2 spark plug tube. I checked it ~ 25,000 miles after this job was done and there is NO OIL IN ANY OF THE TUBES. **
Old 01-16-2005, 02:59 AM   #17
HondaFan81
Moderator
Step # 12
Rocker arm assembly installed. Be sure to first hand tighten and snug all bolts in the proper installation torque sequence. Then, follow through and use a torque wrench and torque the bolts in the installation sequence. This means torquing the rocker arm assembly down evenly as well, which means you have to conduct the torque sequence may times until the target torque specification is reached.
The smaller bolts are 108 in-lbs and the larger are 16 lb-ft.
Reinstall the timing belt and set the belt tension. The timing belt should already be in it's loose state if you have followed the directions. Slip the belt back on, lining up the marks you made previously to keep the cam timing the same. After the belt is on the cam gear, put a mark on one of the cam gear teeth. Now go to the adjustment nut for the timing belt tension (14mm) and loosen it one full turn, then turn the crank counter-clockwise (wratchet, 19mm socket and 6" 1/2 inch extension) until that cam gear tooth mark you made moves the distance of 3 cam gear teeth. Finally, go back to that adjustment nut and snug it down good. This sets the tension on the timing belt.
After reinstalling the timing belt (must have belt on to turn the crank & camshaft), do a valve lash adjustment and set all the intake and exhaust valves to specification. Please refer to a Haynes/Chilton or Helms manual for this procedure. You will need a screwdriver, 10mm combo wrench and feeler gauge with the following measurements:
intake .010"
exhaust .012"
Old 01-16-2005, 03:00 AM   #18
HondaFan81
Moderator
Step # 13
Valve cover is installed and spark plug boots put back in their proper places. The four 10mm acorn nuts are 84 in-lbs and make sure to replace everything that was removed from the valve cover. Remember to reinstall the ground wire and 10mm bolt that fastens it down (below oil cap).
Old 01-16-2005, 03:04 AM   #19
HondaFan81
Moderator
Step # 14
Reinstalled spark plug wires at the distributor end. Having the wires and distributor cap labeled makes for an easy job and no mix ups at this point. That's why I mentioned it previously.
Old 01-16-2005, 03:23 AM   #20
HondaFan81
Moderator
Rocker Arm Assembly Torque Sequence
Rocker Arm Assembly Torque Sequence Diagram:
Note: Thanks to wb7h - Mike for scanning this for me, I didn't have my Helms manual on-hand.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
