What is MIG Welding? MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
What is TIG Welding? TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and HeliarcŪ which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
taken from http://www.daytonamig.com/faq.htm
question...does this mean that whenever I've heard folks refer to wire feed...they are talking about MIG?
is TIG somewhat like stick welding? I know it really isn't but...kinda? like how you have to hold the stick and feed it in by hand I guess.
I've welded some motor mounts with stick welder and they are nasty looking but strong.
I've also welded some exhaust with stick...and with a small wire feed machine. Both did ok...it was easier to fill in holes that I made from holding it in one place to long and blowing it out with the stick welder then the wire feed.
is wire feed also called flux cored?
*edit...found answer on
http://www.nr.edu/welding/processes.htm
it is similar...but a little different
how...not sure...
how...not sure...
__
