My First Turbo Build
    Project Started Jan 16, 2008 expected to be done by Feb 15, 2008.
    Someone told me I needed to make a section in here because this is where the FI Junkies hangout.
    This is my first Turbo install, I have studied a lot about turbos and am very excited to be dropping a 14b in this beloved CB7 of mine.
    Jan 16, 2008 - Turbo Prep Day = All Stripped Down
    Jan 21, 2008 - Intake Piping Fitted/Manifold Painted Black
    Jan 21, 2008 - Johnny Racecar IC installed
    Jan 25, 2008 - Tapped Oil Pan Installed
    Jan 25, 2008 - Removed Header/Exhaust
    Jan 26, 2008 - Block Ground to fit Turbocharger
    Jan 28, 2008 - Manifold and Turbo installed
    Jan 29, 2008 - All vacuum and oil lines installed
    Jan 29, 2008 - Oil Catch Can installed
    Jan 29, 2008 - Boost guage installed under radio
    Feb 02, 2008 - Front Bumper Hack Complete
    Feb 05, 2008 - Install Injectors, Plugs N Wires
    Feb 08, 2008 - All oil lines Installed
    Feb 09, 2008 - Downpipe Installed
    Feb 10, 2008 - Intake Piping / Intake Installed
    Feb 14, 2008 - D112crzy starts the trip up here for tuning
    Feb 15, 2008 - Charge Piping Installed (still need j-pipe welded)
    Feb 16, 2008 - Drive 2.5 Hours to get f22hb to weld some sick piping for me
    Feb 16, 2008 - Turbo Install Complete
    Feb 17, 2008 - TIME FOR NEW CLUTCH!
    Feb 25, 2008 - Left for Deployment, more work upon return!
    Jun 16, 2008 - Ricer Look OUT - Back to OEM!
    Jun 17, 2008 - Spec Clutch Install
    Jun 17, 2008 - H23 Tranny Install
    Jun 18, 2008 - New Gauges Under Radio Install
    Jun 19, 2008 - Poly Filled Motor Mounts Installed
    Jun 20, 2008 - Moving to Maryland no time for cars!
    July 17, 2008 - Ordered Big 16g Turbo (here shortly)
    I will be learning how to tune myself, traded my SAFC to blackice for his hulog, Burn1, and Crome Software, plus a chip and all cables needed to datalog and burn chips.
    First of all the engine checks good, good compression, no vacuum leaks and all. 250k miles so if I blow up engine I dont care. I have an a6 I will be building eventually for boost.
    Here is a list and some pics of the parts I will be running:
    In due time:
    ARP H23 Head Studs
    Head Gasket
    A6 Built Head
    A6 Mani ported
    A6 TB ported
    Fuel Pump/Filter (gunna have to wait till I get back)
    **14b turbo
    **1st gen dsm bov
    **EvoIII manifold with spot for egt(already drilled out)
    **JohnnyRacecar IC, 5 x 26, painted black
    **Steathmode oil kit w/flange for 14b
    **Generic mbc with hoses
    **Fuel Injectors
    **NGK BKR7E-11 Plugs and NGK Wires
    **Oil Catch Can N Lines
    **Oil pan already tapped
    **Oil Pan Gasket
    **Boost Guage (under radio)
    **All vacuum hoses connected
    Car with body panels removed and installing new tapped oil pan, IC already installed...
    mani painted black, throttle body to IC piping setup to be welded one piece with bov flange.
    Thank you to the following people for your assistance in the matter:
    d112crzy (my tuner and answers questions really quickly)
    Junior (helping with the install, practicing tightening bolts)
    blackice (helping with the block grind and photos)
    91 accordlx (coming up and helping with the install)
    f22hb (welded some sik piping and a CB7Tuner logo
    c mak (supplied turbo kit)
    DisDaDrum (Subaru guy for gettin me into turbos)
    and most of the NorthWest scene!
    you can also follow my members ride page by clicking on the link 92 LX in the signature!
    MadLab Racing
    Southern Maryland
    Money
    This post I will be updating everyone on the cost of things I have purchased for the kit and money spent during the install.
    Grand Total 1794.40
    Next Steps:
    Install Fuel Pump/Filter
    Clutch
    Distributor
    Motor Mounts
    $40 - PO6 ECU parts for chipping - D112crzy
    $50 - P06 ECU from 924dr
    also swapped D112crzy a H23 tranny with messed up 4th gear for some ecu work and a tuning session
    Turbo kit purchased from Cmak for $620 shipped
    14b turbo
    Custom bent downpipe with flex pipe
    1st gen dsm bov
    $32.68 Oil Pan Gasket - Autozone
    $4.23 Bolts/Nuts to mount Innercooler - ACE Hardware
    $5.64 Hacksaw blades to remove Header/Exhaust - ACE Hardware
    $7.29 Black Heat Resistant Paint for Exhaust Mani - ACE Hardware
    $38.75 Intake Piping - CXRacing
    $30.90 Mini Turbo Timer - Modacar
    $16 Guage Pod - Under Radio - Modacar
    $46.85 All vacuum and oil hoses/lines/fittings/oil press sensor - Car Quest
    $29.68 Tools / sanding and grinding discs /tape / gasket maker - Home Depot
    $308.77 Injecotrs / Fuel Pump / Turbo Filter / Plugs N Wires - Xenocron
    $20 - Dual Oil Outlet - Stealthmodeperformance
    $31 - Oil Catch Can N Lines
    $50 - Tip to my tuner (d112crzy) for tech support
    $32.28 - Cap/Rotor, DX Alternator Belt, 90 degree bend for turbo to oil feed - CarQuest
    $99.99 - IC Charge piping with couplers - CXRacing
    $55.90 - New Turbo Jpipe - Slowboyracing
    $60.00 - f22hb for welding cause I care
    $40.00 - Another tip to D112crzy for tuning and all his hard work
    $3.23 - Ping Pong Balls for Beer Pong - Big 5
    $11.87 - New Oil line fittings - Skagit Auto Parts
    $33.96 - T clamps and fittings - The Hose Store
    $25.38 - Drill Bit Extractors - ACE Hardware
    MadLab Racing
    Southern Maryland
      good luck man! so will i see you at the next meet boosted?
      My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
      New people click here
        hell yah
        that is my goal, i better be there boosted I just wont be in my EX man, gunna be the LX which isnt as nice but will be fun thats for shure!
        MadLab Racing
        Southern Maryland
          I never realised how small those things are!lol
          Nice build though. Can't wait to see it done!
            It has a bad 4th gear? WTF! You never told me that you fucking scammer!
            Luv ya Steve.
              ahh yah
              well yesterday cory (blackice) helped me out and we ground down the block so the 14b turbo would fit...
              and the final outcome of the grind...
              and then the install with gaskets of the turbo/wastegate...
              now time to order my injectors and get working on the oil system.
              MadLab Racing
              Southern Maryland
                looks like good stuff man, hope to see it come together all the way soon.
                  how come you didnt use your stock ecu and get a map put on that? if its possible
                  ive got an apexi but i want to get rid of that for a chipped ecu so just trying to figure out what to do
                  your project looks good tho...keep the pics coming
                  Hold On Not Done Accelerating
                  Had One Never Did Again
                    because it's not possible.
                      thanks joser, yah stock ecu's most people wont mess with anyways..the p06 is my best option for this turbo build.
                      as far as the apex-i , i used to have one, but I will be running a fully tuned ecu so no need for the piggyback anymore (was just a learning curve for me until I got into the real deal)
                      thanx for the comments tho! pics coming soon of more stuff done, not too much left to accomplish this task!
                      MadLab Racing
                      Southern Maryland
                        awesome...thnx for the info ..looks like im gona have to get myself a p06 also
                        how much psi u plan on running? 7-9psi im guessing?
                          plan for psi
                          yah its a good call on the po6..get em cheap and have joser chip it for ya, hes good.
                          Im planning on runnin 8 psi at first as we all know, who knows after a while I might switch it up to more to destroy the engine, good ole manual boost controller, enabling to get higher psi...
                          good times.
                          MadLab Racing
                          Southern Maryland
                            good stuff, good log of all the work.
                            wish you the best of luck with your boosted life
                            Formerly 91AccordExR33
                            11.68 @ 127mph
                            417whp/375wtq
                            Sold: 8/2016
                              I wish good luck to you steve!! Looks like the build is going good!! I can't wait to hear it running!!
                              97 Yamaha YZF600R
                              Vouches: wagalude/sleepycb7/accordexr33/yeamans17/heylookitsdylan/tommi/JDMH22ACB7/smokeeey420/sackingz123/
                              IDriveALude/Losiracer2/626cb7
