Here is a real-life representation of what anyone can do on a F22ax SOHC non-VTEC motor with bolt-ons, retaining the stock block/stock compression and running 87 octane on a conservative tune.
Car made 152 WHP/127 WTQ on a Mustang Dyno with this setup.
Also, this thread is for reference only, not to brag. This is the basic motor build. Keep in mind these are shipped prices.
Short Video Clips:
RED 40mph+ Pull (2, 3, 4 gear)
* NOTE: Ignore CEL #7 in video above, currently fixed. *
Dyno Graph:
* Delta 272 camshaft regrind set to 0 degrees (most power), retarded and advanced by 2 degrees for comparison *
Tips/Suggestions For Better Performance:
- H23 5spd tranny or even H22 5spd (F22 does it no justice)
- Bisimoto Stage 2 camshaft, lopey idle, still daily-driveable
- Better clutch than Clutch Specialties stg 1 from LSD Motorsports (Competition stg 2, SPEC stg 2)
- Can run higher octane & more aggressive ignition timing tune
- Mill head for more compression, but then need adjustable cam gear to compensate
- Bisimoto F22ax header
- CHR Motorsports F22ax SOHC cylinder head portwork is even better now
- CHR Motorsports offers head reconditioning with EXH port only for $660.
Short Video Clips:
Dyno Graph:
kinda scared to take it high rpms now.. i gotta work on it this weekend to see if i can get this figured out.. i got 287xxx on my engine and i suspect there has been head work done on it by the previous owner cuz the whole top end looks fresh.. after i do that im gonna do my timing belt. how often is that supposed to be done?
