I am so embarassed, I have e 96 jetta, and vw forum is so lame I cant get no help over there. Anyone have kowlege of to fix a german piece of garbage? I cant starts the car and check for arks at night. Just switch out cap, rotter and dizzy along with wire set. I did pull my plugs out to recheck bosh gap and the plugs were black and smelling like gas. Anyone have idea.
My other car project 96 jetta
Thanks guys, I love you guys. K, I figures it out. I had the wrong firing order, but I ran the car 14 miles and it crap out agian. Same issue, it bogged down. It felt like it was out of gas, I had to rock the car to with the steering wheel so the car can pick up some rpms and coast abit further. Anyways, i have to go back to and make this car drive back home so I can work in on the issues. Pulled two new codes po422 & po137.
Fault Code Definition
The Powertrain Computer or PCM has determined that the Oxygen Sensor voltage remained below 400 millivolts for more than two minutes (varies with vehicle make and model) or that the Air Fuel Ratio Sensor remained in a lean-biased mode for too long (varies with vehicle make and model).
OBD II P0131 Oxygen Sensor Circuit Low Voltage (Bank 1, Sensor 1)
OBD II P0137 Oxygen Sensor Circuit Low Voltage (Bank 2, Sensor 1)
Symptoms
Check Engine Light will illuminate
Vehicle may idle or run rough
Decrease in fuel Eeconomy because PCM is in a "limp home" mode
Engine dies
In some unusual cases, there are no adverse conditions noticed by the driver
Common Problems that Trigger the P0131 and P0137 Code
Defective Oxygen Sensor/Air Fuel Ratio Sensor
Defective Oxygen Sensor/Air Fuel Ratio Sensor Heater circuit
High Fuel Pressure
Defective Engine Coolant Temperature Sensor
Defective sensor wiring and/or circuit problem
PCM software needs to be updated
Defective PCM
Polluting Gases Expelled
HCs (Hydrocarbons): Unburned droplets of raw fuel that smell, affect breathing, and contribute to smog
CO (Carbon Monoxide): Partially burned fuel that is an odorless and deadly poisonous gas
NOX (Oxides of Nitrogen): One of the two ingredients that, when exposed to sunlight, cause smog
Want to Learn More?
The purpose of codes P0131 and P0137 is to track the amount of time that the Oxygen Sensor or Air Fuel Ratio Sensor stays in a lean signal/condition before moving to a rich signal/condition. If the signal stays stuck in a lean mode and/or is set below the lean to rich cross count point for 2 minutes or more—which is generally around 400 millivolts for an Oxygen Sensor—then the code P0131 or P0137 is triggered.
The switching time of an Air Fuel Ratio Sensor can also be observed using a scanner, though this data is only an approximation created by the Powertrain Control Module for diagnostic purposes. In order to set, this Oxygen Sensor/Air Fuel Ratio Sensor code usually requires malfunctions on two different drive cycles by the vehicle; however, if the problem is severe enough, the code can set in less than fifteen minutes on an initial test drive, after the clearing of all codes. In other words, the code setting criteria varies from vehicle to vehicle.
you may have a bad cat po422 also refers to oxygen sensorLast edited by cb7attack66; 06-15-2012, 06:51 PM.
Symptoms
Engine dies
High Fuel Pressure
Defective PCM
Want to Learn More?
think 2.. up stream and down stream o2 sensors you could also have a clogged/bad catalytic converter..when you go from side to side the metal catalyst inside could just be shifting around. you could even be experiencing a fuel line becoming pinched when car moves around ..you said you were smelling gas before? im leaning towards cat,,or could be electrical,,check the wires around your o2 sensorsLast edited by cb7attack66; 06-15-2012, 09:50 PM.
Last friday I double check the firing order, i was off, had to look up the correct order. I ran the car 30 miles, and got stranded. Same results, car sputtered to a complete stop. I noticed [P] (Parking light) is flikering, is that a code going off? I still got black smelling spark plugs. I had to have the jetta towed home, havent donw a thing to it.
