I just went to advance today and i put an a20a1 head gasket on my b20a5 head and it is reasonably close. I'm thinking that if i jbweld up the 2 oil passages on the intake side (i think..might be exhaust) and drill out the gasket a little bit that i can get the thing to fit. Granted it's not an exact fit like the f22/h22 frankenstein, but it's somewhat the same concept. I dont have anythign to lose on this particular swap because the cause the carb on the a20 is going bad so it's running terribly bad.
what i'm planning on doing is hooking up the computer to the wire harness and remove anything not connected to it... BTW does anyone have the pinout of the b20a5..if not i'll search around for it somewere.. I'm stinking that if i just run the wires for the computer only i'll be okay this way everythign still works in the car. I'm going to do the normal thing of taking out the gas tank and adding a pressure line. I think i'm going to need some serious luck on this one. I've seen the b21a3 on the a20a1 before...i just dont think that is the only option.
i'd ask over on 3geez.com since i've been there for ever, but i think that they dont have the mind set cause i'm seen on here people thinking more and more about head swaps because of hte f22/h23 head swap. ...just how i feel..
Anyone have concrete evidence that it's not going to work? Once i finish up my buddies zook i'm going to start rebuilding the b20a5 head and get his car over...dang this is alot of work.. anywho i just wanted to put down my ideas on...umm cyber paper and get others opinions on this thing.
peace
peace
