V6 Accord motor in 1940 Chevy
    I need to know if there is any place that I can send my OBD2 ECU from a 2004 Accord and get reprogramed so I can use the Accord V6 motor in my 1940 chevy. The V6 motor that I am using is from a 2004 Accord I got the motor, ecu, and complete wiring harness.
    da9b16 is a great seller very quick shipping and great parts
    Put your flame suit on....Why would you do such a thing?
      WTF haha.
      you could always just do an OBD2 -> OBD1 conversion.
        don't you need a transmission too? plus why does the ecu need to be reprogrammed anyway? it's not like the chevy is even fuel injected, let alone running an obd system.
        .:1993 EX-R Sedan:..:psyphredotcom:..:mrtazzymotorsports:.
          www.ericksracing.com
          but you said it's 04 engine/ECU which is OBD2b and no one that I know of reprograms them yet.
          Look for the pre- 2000 ECU (OBD2a) and see what ericksracing can do for you
          My Accord History:
          91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
          -Patrick
            is there any place that will tune a V6 ECU not just the L4. The transmission i am going to use is a chevy 700r4 custom modification to the bell housing and flex plate. the motor that i am using is the J30A4
              As far as I know, you don't have any other options besides the OBD2b > OBD1 conversion harness and using an OBD1 ECU.
              The 700r4 is a badass trans! I'd like to know more about your setup and see some pics if I can! Are you using a lock-up converter? I guess that question and most of the other questions I have depends on if you're gonna use it as a daily driver or a track truck. You got a place that will balance the flexplate after you hack it up and re-weld it?
              My Accord History:
              -Patrick
                ok which OBD1 ECU Can i use? The 94/95 V6 or what?
                  700R4 is alright if its built right, They tend to break down in high hp usage. I prefer the th350 personally. My teach has built a couple of 700R4 for drag cars its a good tranny just gotta know where to mod.
                    Somebody ate mag and aluminum polish again...
                    (RIP)1993 LX Sedan
                    Frost White Crew Member #36
                    JDM Beating Stick Owner #1
                    My (old) Ride
                      It would be a lot easier to get an AEM programable ECU then mess with the wiring required from factory. AEM # 30-1002 plus connector AEM # 35-2611 that'll fix er up perfect! The only other item you may need is a distributor.
                        thanks guys for the info ricks racing will not program an ecu so i am going to buy an 1995 ecu and go from their. my other question is does anybody know what the easiest way it would be to mount the 700r4 tranny to that block
                          LOL you need to custom it. Need to somehow make the splines line up and shit. Apparently your gonna be spending a shit load of money....Why didnt you just throw in a GM crate motor or something.
                            i got the motor for free the only thing i need now is to get the tranns welded and then the flex plate re-ballanced
                              why do you need to reprogram the ECU if its the proper ECU for the motor, and you have the full harness?
