18 Inch Rims
    18 Inch Rims
    I bought some 18 inch rims and got them installed but the tire profile is way 2 low for me. its 215/35ZR18.
    I was wondering how much thicker i can go with the tires without any scraping.
    On stock height , you won't have any problems with 45's.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      thanks for the help, much appreciated
        i have 215/45/18 and still have plenty of space left, but its gonna get lowered so not going any thicker
          what method are you going to use to lower it?
            With a 45 side wall the difference between stock tire size is -1.406.
            when changing tire size the difference in overall wheel diameter must fall within -/+ 0.4 in of stock tire size
            A 40 series sidewall tire will be better for 18's as the overall wheel diameter is only a -0.5 difference from stock.
              on my 92 4 door a few years ago, I was running 18" tenzo R RS5's. I was using a 225/40/18. its was lowered about 2.5-3 inches and didnt rub. but i also rolled my fenders. the only reason i did was because they fronts WOULD rub if i hit a bump while turning sharp. didnt rub bad but rubbing is never a good thing
              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=183959
                45 is the proper aspect ratio for a 17" rim. On an 18" rim, that's going to be quite thick. 35 is the proper size for the rim. If that's too little tire for you, get a smaller rim.
                If you get a thicker tire, at least be prepared to have a speedometer that reads much slower than you're actually going. Get a GPS unit or something that will show you your speed, and note the difference (it will be a ratio... so it may be 5mph off when it says 30, but 10mph off at 75...) Otherwise, you'll find yourself getting speeding tickets left and right.
                  my speedo is already off by about 5 even with stock rims on it. i just deal with it.
                    ^ totaly agree! If its to small of a tire get smaller wheels like 16-17s
                      215/35/18. Same size that's in the pic in my sig. I had no issues.
                        You wont have any problems if you do a 2 inch drop no rubs
                          thanks for the info i have a drop planed for the future
                            Keep in mind that you have to get the correct offset as well.
                              there was a thread regarding tire sizes where i was told that different sized tires/rims would not affect the speedometer, i am confused now, please help
