I just bought a new steering wheel and it dosn't have cruise control buttons. I got the wheel mounted up and I know the 2 cruise control wires are light green and red and light green and black. I bought some "momentary" switches for the set/decel and the resume/accel buttons. The switches are very small and im going to mount tehm somewhere, but there are 2 metal prongs on the back of each of them and im wondering if one is the ground and the other is for the cruise wire??? Im just not sure how to hook it up to the new switch, im assuming its grounded on one prong and the cruise wire on the other so when I push the button it temporarily closes the circuit and activates the cruise... Am I wrong? any info helps... I have a manual so i know the wire colors. Thanks a bunch!- Eazy
91 accord cruise control wires???
Originally posted by eazyduzit509 View PostI just bought a new steering wheel and it dosn't have cruise control buttons. I got the wheel mounted up and I know the 2 cruise control wires are light green and red and light green and black. I bought some "momentary" switches for the set/decel and the resume/accel buttons. The switches are very small and im going to mount tehm somewhere, but there are 2 metal prongs on the back of each of them and im wondering if one is the ground and the other is for the cruise wire??? Im just not sure how to hook it up to the new switch, im assuming its grounded on one prong and the cruise wire on the other so when I push the button it temporarily closes the circuit and activates the cruise... Am I wrong? any info helps... I have a manual so i know the wire colors. Thanks a bunch!- Eazy1992 Prelude S w/swapped H22A
You should have three wires there. Blue/Red, Light Green/Red, Light Green/Black.
If you put the blue/red and light green/red on one switch, that might make your Set switch.
Blue/red and Light green/black should make your Resume switch.
As you can see, you will have to create a Y on the end of the blue/red, because you need to use it twice.
I'll bet that circuit board just doubles up the blue/red wire.Last edited by benji; 08-09-2008, 02:07 PM.1992 Prelude S w/swapped H22A
