Help? Turn signal.
    Help? Turn signal.
    My car makes the sound as if the turn signal is on, but it isnt actually on. It's just making the sound.
    Has anyone had this problem and do they know how to fix it.
    I tried to search for this and didnt come across anything.?
    I want to try to get this fixed today.
    Probably the realay is bad.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      How would I go about fixing this issue?
      I mean the turn signals still work and everything when I actually turn them on, its just when there not on, I still hear the clicking like its on. :/
      and it's a bit annoying.
        The relay in under the dash. I believe on the kick panel fuse box. It should be clicking. Just replace it with a new one or preferrably yank one off a yard.
          I had a similiar problem and after changing the relay didn't resolve my issue, I replaced the turn signal stalk and there have been no more problems. Just another thing to check for.
          *my burned out turn signal is actually how I met my good friend and fellow cb7tuner, new_beginnings who was parting a cb locally on cl
          "I'm a dude playing a dude, disguised as another dude"
          "That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
          Romans 10:9
          ><((((º>
            Relays don't actuate by themselves. The magnetic coil within is being energized/grounded due to a fault in the circuit. Better break out that test light.
            "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
              Yes, my mom's LX was doin that exact same shit and I replaced the relay with no luck. I hit up the J.Y. and snatched up a turn signal itself (I actually just bought the entire thing that goes around the steering column wit the turn signals and wiper) and replaced it and it works fine now. I'm willing to bet that you got the same problem.
                It has to be the switch or worse some wires touching.
                1993 Accord EX
                2011 Subaru STi
