I just installed the f22a6 manifold, and i fell it kinda slow for some reason and when i shift it backfires all the gears, it doesn't matter how high my rpms are, and by the way when I rev it up high and let go on the gas it pops somekind of a white smoke. These are my issues, any ideas?
f22a6
if you have white smoke coming out then your burnng coolant somehow. are all your gaskets seated and sealed properly? did you scrape the old gasket off completely and clean the surface?
it might not be a problem with the manifold. it might just be a coincidence. white smoke definitely suggests that your burning cooland and that could be the answer to all the questions. the loss of power and popping because of the improper combustion would make sense.
