I found out that my gas tank is leaking around the seam i doubt i can patch it with something so i need to replace it. As far as getting the gas tank i thought it would be better to buy new but my brother suggested to get from the junk yard, I dont know to which to buy. Also to put the new gas tank in i dont know if i should do it or to get a mechanic, i have a haynes manual i read the instructions it doesnt seem to hard to replace. Any suggetions?
leaking gas tank
Def. do yourself a favor and get a new tank, a junkyard tank where you are prob. won't be any better unless it's a fairly new one. I would also coat the tank w/ spray on bedliner. I say go for it myself if you're up for it! I'm picking up a BNIB tank tomorrow (craigslist), will coat it and install it in the early spring.
Its fairly straight forward. A jack is nice to have when putting it up and down. use the drain plug to get all the gas out before you bring it down. Clean the area around the drain plug so you dont get shit in the gas.
Spray with undercoating/bed-liner. Unbolt the 2 straps, remove them from the car entirely. the heatshield for the exhaust being removed allows for some extra room to work with.
remove connects for fuel pump (after removing all the shit from the top of the pump, dont get any on the sock either. I recommend getting a new fuel pump sock if you can.
GL.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Originally posted by Diesbourg View PostI found out that my gas tank is leaking around the seam i doubt i can patch it with something so i need to replace it. As far as getting the gas tank i thought it would be better to buy new but my brother suggested to get from the junk yard, I dont know to which to buy. Also to put the new gas tank in i dont know if i should do it or to get a mechanic, i have a haynes manual i read the instructions it doesnt seem to hard to replace. Any suggetions?
Originally posted by deevergote.......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
