So, when you post a thread about power, you're told 3 things.
1. Turbo 2. Build the f22 3. Swap an h22.
I've put about a year of thought into all of this, and noticed kids with 140-150-160whp with ease on the f22's.
As for the mild setup:
-short-ram intake
-header
-2.25" exhaust, universal cat, straight back to muffler
-in the process of throwin' a h23 intake manifold in (entire thing)
Now, my next step is to go sorta big, which is the camshaft regrind. I've been checkin' out bisimoto's site and it's the same price for a level 1, and leve 2. I have an automatic, and don't plan on swapping to a 5 speed anytime soon. If I was to ever do a tranny upgrade, it'd be to a h23 or some sort of tranny with shorter gears.
With the regrind, I'd like to go to a level 2, since they're the same price..so why the hell not? Thing is, it says spring upgrades are recommended. Level 1 doesn't really recommend a spring upgrade, but does recommend a cam gear (for all levels), which I'll get that also. Other thing is it bein' an automatic, people recommend the delta 260 for autos, and 272 for manuals. Would that be the same as bisimoto level 1 for the auto, and level 2 for the manual?
Last thing, is an ecu. I read about quite a few ecu's for anytype of upgrade. Turbos, big internals, all-motor projects, etc. To get the most out of this cam, I'd need a ecu to get tuned. Questions are 1. what ecu should be used? 2. gettin' the ecu tuned. I know there's members that do it, but can I just tell them my exact setup, and have the ecu tuned, or do I have to go through dynos and stuff?
I've been doin' research on all this stuff for the past week (which is why I'm shooting for this, because of a members numbers he got from i/h/e, cam, and tuned ecu which was what...141whp?) I have a f22a6, which are rated at 118whp, and this dude got 141whp out of his a6? That definitely got me motivated to attempt a build on the f22.
If you need me to explain more, I will. I try to be as detailed as possible.
-short-ram intake
-header
