h22 tranmission
    h22 tranmission
    i have notice that i am leaking trans fluid
    not alot but enough to drip and cuase a small stain in the ground
    its leaking at the botten in two spots , ( were the bolts hold the tans together )
    is there an easy fix
    -1992 CB7 EX w/H22 [sold 10/09]
    -2005 Legacy GT limited [current]
    So it's leaking where the 2 halves join and not where the tranny meets the block? That is not very common at all, not sure if there's a way around it, but the tranny would have to be opened up and resealed.
      oh shitinzcrackers , that is where it leaks , not between the block and tranny
      you think i could some how seal it with out opening it up
        I knew it would be possible, but I have never personally seen it happen, that is very unfortunate I would probably jump over to HT and see what you can find, there may some bandaids for your problem, not sure though. Sucks though, which H22 tranny are we talking about here? What's the mileage, any other problems?
          usdm 2001 tanny - non lsd around 35,000 k
          these leaks are def. premature
