Best flowing intake mainfold.
    I am building a F22A4. What would be the best flowing intake manifold out of all the Honda engines that would bolt right up? Basically, something I would look for in a junkyard.
    Sold!
    Selling: F22A4(disassembled)
    a port matched gasket with the H23 plenum attached to the A6's runners would be the best bet.
    while it's out still don't forget to clean everything on the inside of carbon and all that jazz.
      Definetly gasket matching whatever goes back on. Thanks for the reply.
      Sold!
        i heard the 96 civic ex plenum is good
          d series and f/h series aren't compatable.
          spoonsportsaddict
            Tig welder says otherwise..
            Lmao..
            I totally kidd..
            Praise The Lowered...
              H23 upper, A6 lower, doublestack spacer, then gasketmatch/port slightly.
              Ill tell you from expirience you will love it on an a4.
                get an a6 lower intake and do this
                Just do what PR CB7 said.
                  Did you do that yourself? Or send it somewhere to be done?
                    a lot of sweat, beer and 1 week of hard work
                    i saved $300 though
                      What kind of beer?
                      The quality of the cerveza determines the quality of the port work..
                      Quality booze is key..lol
                        H22 and H23 intake manifolds the same?
                        Sold!
                          Upper manifolds are the same, throttle bodies are different.
                            No you are wrong. The plenums and the throttle bodies are the same between H22 and H23's. The runners are different. The H22 runners will not fit on F series heads while the H23 runners will.
                            PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
                            Listen or download the first 4 songs I completed for my new upcoming album here!!
                            My member's ride
                              as far as the beer CORONA
                              as far as the TB w plenum
                              u'll find that even on the h23 mani, which has a p14 stamped (p14=h23)
                              the plenum will say p13 (p13=h22)
