i need to get the egr ports for my h22 cuase i want too clean the carbon out ,but the parts center at the honda dealer cant get them , where else can i order these 6 plugs ?
EGR ports , Honda dealer dont have them ?!?!
Originally posted by F22HB View PostThe parts should have them, thats kinda weird. You can always do the cool thing and tap them and put threaded plugs in.
At least on all the F22A runners, the larger 7th port @ the very end (cyl. #1) is ready for a 1/2" set screw, I enlarged the other 6 to the same size, so on all 7 I used 1/2"-13 set screws (local hardware store, no need to order these) w/ teflon tape and loctite, worked well. I'm not running EGR, but I wanted to do this anyways while I was "building" a whole IM setup. Anyways, w/ H22 runners, maybe you could do the same thing, aren't those usually welded over though instead of visible brass plugs?
