auto to 5speed swap prblem
    i changed the transmission. but now my motor mounts dnt wanna line up i dont know why. any ideas. i would really appriacate it.
    R.I.P 93 CB7 COUPE
    Team modA in the proess
    did u get the 5 spd tranny mount???
      You need to weld in the mount bracket from the 5 speed donor car. The bracket in the automatic will not line up properly with the 5 speed transmision mount.
      Or you can buy the conversion mount from www.explicitspeedperformance.net and avoid all welding.
        thanks deevergote thats a good source. i think i might just buy it from them.
        R.I.P 93 CB7 COUPE
          see if you can put in the manual cross- member? then it should all bolt up. right?
          Accord SE
          93se
          Members Ride
          Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
          Sold to: sulimed, BurtonRiderT6, tishock
            No. The transmission mount bracket is welded to the unibody, not the crossmember. The ESP swap mount is the best solution out there. I did mine before they started producing them, so I had to remove the old bracket and weld in a new one in the correct position.
            If you're getting the swap mount, I would suggest getting the entire kit. Definitely worth the cost! I have their kit and I am VERY happy with it!
            Originally posted by Junior Smurff
            Nevermind guys, google search works wonders!
            I don't have road rage, my car just goes faster than yours!
            Accords are for winners. And Grandmothers. But mostly winners.
            I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
              ah. well cool. im gonna be getting the esp kit. but i just herd something about that.
              Accord SE
              93se
              Members Ride
                what did you hear? is it good or bad
                R.I.P 93 CB7 COUPE
                  it good. just something about using the manual cross member. like it makes sense...this guy that is gonna swap it for me i bought my car from and he has done a swap before and did something like that i assume... he has a whole nother cb7 for parts so ya...
                  Accord SE
                  93se
                  Members Ride
                    oh ok. but yeah so far im getting that mount. im jus wondering if i still have to use the m/t rear motor mount bracket. or the a/t one.
                    R.I.P 93 CB7 COUPE
                      use manual
                      Accord SE
                      93se
                      Members Ride
                        The crossmember is no different from auto to manual.
                          its the rear mount that is different for you urs is an se/ex so u need a dx lx rear mount plus the esp kit. the crossmember wont do anything but take more time and do nothing. the hole are already predrilled and threaded if u have any more question man give me a shout im like 20 mins from you and my swap is done except the clutch line.
                          Members Ride sold...
                            Unless you want to replace the crossmember with an ESP traction bar... which you can order at the same time as the mounts. THAT would be an upgrade.
                              that would be very nice. but im just a very tight budget. but if i was able to get it i would
                              R.I.P 93 CB7 COUPE
