Another Tranny Question
    In 90-93 accord can the shifter cables be adjusted because my 1st 3rd and 5th gear will not lock in place they slide back to neuteral everytime im driving in one of those gears... I have a 5 speed h22a with a h22 tranny
    Modded shifter or stock CB or Prelude? Sounds like you are hitting the stop on the shifter plate. Probably have to cut down the forward "finger" off the shift lever. I think 90 shift cables were adj'able, 91+ are fixed length.
      i used the stock accord cables for the h22 tranny should i had used the prelude cables or are both the same
