F22 frank engine has bouncing idle (please help me)
    Hey guys, I got my f22 frank engine running but need help with jumping idle. It has a h23 head and intake on it. It runs but the idle goes from 1000-1600-1000-1600 or so. Just up and down. I am still running the pt3 ecu on it. I have searched and tried a few things but no luck.
    I've taken the ficv that is under the throttle body off and tightened the white plunger down. It was loose about 2 turns.
    Replaced the iacv with the plug in on it with the old one from the f22 manifold on and still no change.
    Checked intake bolts and gasket and they are all on good and tight. No change.
    Tried blocking the iacv with a piece of cardboard and no change.
    Now if I unplug the iacv the check engine light comes on but it runs better. Kind of a lope to it like it has a cam? But doesn't go up and down. I can only run it a few times after work because it is open headered.
    I have a appointment on Friday to get exhaust so would like to get it figured out.
    Please help me guys!
    of you unplug the iacv and it stoped jumping then that ur problem even with the iacv unplugged it will still jump depending on how the biss screw is and the temp of the engine u can still run it with it unpluged i did that with my 91 eclipse and that loping u might have a missfire that happend with myeclipse to i didnt find out about the missfire till i unpluged the iacv
      mine used to do that baaaadddd. i took it to the dealership and they found out that the idle speed was set too high and the computer was trying to compensate and lower it so it just bounced.
      COUPE K24
        play with vaccum lines..... lol i had a bouncing idle for 5-6 months and recently discovered it was a mix up on vaccum lines.
        Members Ride sold...
          Idle speed might be it. I know it's not misfiring though.
          The throttle body and intake is all different so no idea how it was set
            i read a diy thread on how to set it hears the link... http://www.cb7tuner.com/vbb/showthread.php?t=146239 cheack that, iacv, or vac line idk anything else it could be a easy way to sheack for a vac leak is to sea foam it look nder the hood and if u see the sea foam comeing out the engine track it down thats how my friend found a vacume leak he didnt know he had
              Lol, I was told the vacuum lines don't matter it's all the same. The fpr goes to the nipple right behind it, map sensor is the nipple on top of the throttle body, brake booster hose and everything else is capped off.
              Should point out that my old iacv worked good before the swap, it starts doing it about 30 seconds after I start it, and that I don't know if it matters but I do not know if the h23 stuff was from an auto or manual car if it matters
                yes the lines do matter!!!!! and can you take pics of what you have? and do u have a black box for the IABs?
                  I can e-mail pics but can't post them. I do not have a black box, I gutted out the plenum spacer.
                  As far as vacuum lines go, the fuel pressure regulator goes to the single nipple right behind it. The map goes to the little nipple on top of the throttle body, and everything else is capped of with plugs. The fast idle thing is also capped of as well as the egr.
                  Like I said too, this does it about 30 seconds after I start it.
                    Wheres your air boost valve hooked up to? It should be connected to the intake manifold before the throttle body, if you connected it directly to the plenum, it would cause the problem your describing. You could also block it off, and see if it is the source of your vacuum leak.
                      Right now it is capped off. By blocking it off do you mean where it bolts to the plenum or just the nipple?
                        Well fuck me bro, I was searching the forums and saw a post you made about swapping the throttle wheel from the f22 onto the h23 throttle body, saw a pic and saw a vacuum hose on the pic I didn't block off.
                        So long story short I have a vacuum leak at the nipple right behind the throttle bracket in front of the plenum.
                        Now, do I really need to swap the wheel thing and do you think that vacuum leak would cause the up and down idle?
                          i did not know this currently mine is not hooked up to anything lol.
                            The only time you would switch the throttle wheel, is if you have an automatic and get a manual throttle body, because of the automatic kick down cable.
                            As for the nipple thats not plugged in, cap it and go through the setting a base idle procedure again.
                              Ficv
                              I Have A F22a6 And I Wanted To Knw If Anyone Knows If I Take The Ficv What Would Happend
