First things to do to your stock cb7
    what are the best things to do to your stock f22 engine
    to take it from 20 years old to good as new
    example:
    new wires
    new plugs
    new belts...
    and so on
    thanks for the tips
    ^^MRT^^
    THIRD EYE FISH
    Plugs and belts, look at them and do as necessary. Except the timing belt, if you have no idea of its age, do it.
    Get a Haynes manual and read the regular maintenance schedule. That should give you good ideas.
      If you want your car running like a champ, here are a few things you can do yourself:
      1. Set Ignition Timing
      2. Valve Adjustment
      3. Clean throttle body, replace air filter
      4. Clean IAC Valve
      5. Clean EGR Ports
      6. Replace spark plugs, plug wires
      7. Replace Oxygen Sensor
      8. Fresh Motor Oil
      If you decide to do #3, 4,and 5, be sure to properly set your idle. Most of these procedures have guides in the DIY section.
      EDIT: Potatoswatter is correct. A shop manual should provide a good maintenance schedule guide.
      Original-Owner 1991 Honda Accord
      2005 Acura TSX 6MT
      2010 Mazda Miata Grand Touring
        For a start I would look up your service manual see what a major service entails (a 100,000 km or 60,000 miles service)
        It would include items like:
        All fluids (transmission, radiator, brake fluid, engine oil etc).
        Timing belt replacement (incl. water pump, front seal, balancer belt, power steer and alternator belts unless you know its still good).
        Air Filter check and replacement if required
        Spark Plug check and replace if required
        In addition
        Check and replace brakes/rotors if required
        Check and replace ball joints, suspension bushings if required
        Do wheel alignment etc.
        For a newly acquired CB (or any second hand car) I would advise on just focusing on existing repairs first, preventative maintanance second eg. servicing every possible item you can think of and replacing every part that doesnt look healthy (eg. swelling hoses - which we have a ton of under the bonnet, wiper blades, suspension rubbers etc), accessories and mods very very last.
        Rides:
        Accord
        92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
        96-AUDM-2.2 VTiS- Heather Mist
        CR-X
        88-JDM-Si- Black
        CR-X Del Sol
        92-JDM-SiR "Transtop" Motegi Edition - Silver
        95-JDM-SiR "Transtop" Daytona Edition - Silver
        92-JDM-SiR "Transtop" - Black
        Prelude
        91-JDM-Si-4ws "Si States" - Phoenix Red
        91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
        91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
        91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
          In addition
          this would be perfect right after i save up another 600...
          So I was thinking what would Jesus drive?
            first thing id do would be swap a rebuilt h22. this is coming from a nonvtec guy too.
              yea i just changed the oil, spark plugs, trans oil, and minor stuff like that.
              i would do the sticky caliper diy if the car was sitting very long. did mines and the brakes are alot better
                u can do new fuel pump and fuel filter
                  Filter certainly. But why would you replace the pump?
                    You didn't know Potato. Because Honda fuel pumps go out about every 250,000 miles. You can never be too careful.
                      he's talking about getting his mecanic/car to run like a new not to go over a swap. And personaly i think this is a noobish answer, get problems fixed before going on major change. A nice looking car with a good motor but with bad brakes, suspensions and direction = dangerous as fuck!
                      1992 Accord EX-R Coupe [Mat Black] Sold
                      1992 Accord EX-R Coupe [Rosewood]
                        2. Valve Adjustment
                        4. Clean IAC Valve
                        5. Clean EGR Ports
                        8. Fresh Motor Oil
                        Why would you have to set idle properly when cleaning the throttle body, IAC Valve, and EGR ports?
                        Thanks.
                          What about cleaning the fuel injectors? Would this be advisable?
                          Thanks.
                            Suspension. I hate driving a car that drives like shit.
                            Balljoints
                            bushings
                            tierods
                            wheel bearings
                            and kind of related
                            brakes
                              Balljoints
                              bushings
                              tierods
                              wheel bearings
                              and kind of related
                              brakes
                              What bushings should be changed? Please list so I can check and change them. Wheel bearings, unless they are bad, would you change them before they are going bad?
                              Thanks.
