So I was at Pep Boys the other day and they suggested that I get high mileage oil.. What's the diff? What benefits am I getting?
Oil?
Not sure, some of them have different additives like more detergent and stuff.
If you have a well running Honda engine you probably don't need the high mileage oil. My car has 220k on it and I've never used anything but standard 5w-30 and 10w-40 the whole time. It still gets 30 mpg straight up and doesn't burn a drop of oil (leaks some, though!).
Basically, I guess you could summarize my comment as really being "I have no idea."
Originally posted by C-Rod View PostSo I was at Pep Boys the other day and they suggested that I get high mileage oil.. What's the diff? What benefits am I getting?
and from what my teachers tell me...as long as you run the oil your suppose to your fine!
oh i forgot to mention im completely stock so no suspension upgrades. lol
hi, i changed my oil recently, i used castrol gtx, the guy said oil now is made to last longer than ever, because i asked him about syntethic oil, which 1 should i get even tho i was gonna walk outta there with gtx.. i wanted to see wat he'll say.
i change my oil every 3k.**Blk Housed Slut Crew Member #1**
The only problem with synthetic is that it's thinner than conventional oil. If your engine has leaks, synthetic will find them faster. Granted, that's not a problem if your motor is healthy... but if you don't keep an eye on your oil level, it can be a big deal.
High mileage oil is never a bad thing... but to be honest, as long as you maintain your engine, and don't abuse it, regular oil is just fine.
@ F20A i honestly dont believe it would be safe to start running a car with synthetic oil on a egine with high milage that has been ran on conventional oil in entire life. another thing is you cannot switch back "safely" to conventional oil once synthetic is used. making your oil changes that much more expensive.
@ Op High milage oil benefits your engine by introducing detergents into the system that after being ran a full cycle can clean and better lubricate your engines moving parts. I would say run it if you feel you need to, but i cantell you that if you go to a lub shop like jiffy lub or even wal mart they check your odometer and use the apropriate oil, if its high milage "above 150K" they will use the high milage brand and it doesnt cost more, and if it does its cents on the dollar, not like the difference in cost between synthetic and conventional._____________________________
91 Accord F22B
Originally posted by Slice One View Post@ F20A i honestly dont believe it would be safe to start running a car with synthetic oil on a egine with high milage that has been ran on conventional oil in entire life. another thing is you cannot switch back "safely" to conventional oil once synthetic is used. making your oil changes that much more expensive.
And as long as the engine has no leaks switching to synthetic is not going to cause leaks that were not previously there.
and NEVER...take your car to wal mart for anything...better than jiffy lube I guess...but...they like to double charge you for everything...you would not notice unless you checked the receipt. They gave us a quote one time for tires, I noticed their charges did not add up to what the total was. They charged twice for things...it is in the total but not on the paperwork.
The ONLY con for todays synthetics is if your seals are old and worn...but if they leak with synthetic oil then it IS beyond time to replace them.
Do not blame your oil for BAD SEALS! Switch to castrol syntec (unlike others...it really is synthetic), change your filter every 5k, and change the oil every 15,000 miles. If you leak oil...replace the worn seals! Common sense really.
I have over 226,000 miles and drive hard...synthetic ftw____
