so im still piecing together my turbo project. i know the bigger the better with an inter cooler. but what is a good size that will fit with minor modification behind a stock bumper.
1992 honda accord f22 turbo intercooler
Deciding on your boost levels is what you would determine for your intercooler size. From my understandings, is if you were going to run a large amount of boost than a large intercooler would be needed. Where as if you run low boost anything from a 24" intercooler would work.
Example:
Low boost.
http://cgi.ebay.com/ebaymotors/Inter...Q5fAccessories
Large boost.
^I will vouche for Meyagi Tuning services anyday, highly recommended.Last edited by Granite CB7; 11-25-2010, 12:28 PM.
lodollar what color is ur swaped legacy. i saw one at sanford sound car show this year.
thanks for the help guys
and lodollar what do you usually charge for tuning? i was thinking about running crome or neptune.Last edited by JoshM; 11-27-2010, 06:37 PM. Reason: you can type more than one thought in a single post
that was me.
as far as the intercooler fitment goes, no matter what size you get, bumper mods are required. if you get a 2.5" thick core, you can usually get pretty creative and hide it behind the stock bumper without too much cutting.
if it were me, id weld 2 90deg aluminum elbows to the endtanks and run the pipes back past the radiator on both sides, to avoid cutting up the bumper some, and for alot less pipe, which means less lag.
